POV-Ray : Newsgroups : povray.general : Newbie: Candy Cane stripes on a cone? Server Time
12 Jan 2026 23:26:10 EST (-0500)
  Newbie: Candy Cane stripes on a cone? (Message 1 to 6 of 6)
Subject: Newbie: Candy Cane stripes on a cone?
Date: 13 Oct 1998 19:15:52
Message: <3623D03E.ED84F44B@argoneng.com>
How would I do candy cane stripes on a cone?
I've looked through the docs, can't seem to find what I'm looking for.
Any ideas on how I could do this?
Ideally I would want the z distance of the stripe height to stay the
same
(so the stripes appear to get bigger down the cone simply because
they're
taking up more area in the other directions).
-JamesF.
Subject: Re: Newbie: Candy Cane stripes on a cone?
Date: 13 Oct 1998 22:37:49
Message: <36240052.B4D48CBF@pacbell.net>
For  a clue how to do it look at the textures in textures.inc.
Down at the bottom of the list of textures are some examples
or spiraling stripes called coincidedntly Cane.
Ken
> same
> they're
> -JamesF.
Date: 13 Oct 1998 22:58:55
Message: <36240543.D98C59D4@flash.net>
From textures.inc :
// Red & white stripes - Looks best on a y axis Cylinder
// It "spirals" because it's gradient on two axis
#declare Candy_Cane =
    gradient x+y
    color_map {
        [0.25 rgb <1,0,0>]
        [0.25 rgb <1,1,1>]
        [0.75 rgb <1,1,1>]
        [0.75 rgb <1,0,0>]
Note this is not a spiral, but simply rotated independent
stripes.
A functional linear combination of gradient y and radial
with an appropriate pigment map would do the
trick, but I am not sure if the syntax exists to do this.
Of course, one could always use an image_map with cylindrical
mapping.
Dan
> Ken
> > same
> > they're
> > -JamesF.
http://www.flash.net/~djconnel/
Date: 14 Oct 1998 17:20:49
Message: <3625075C.3FE0@t-online.de>
> same
> they're
> -JamesF.
Could be this, what you're looking for:
//PoV-Code~~~~~~~~~~~~~~~~~~~~~~~~~~~~
cone {<0, 0, 2>, 3, <0, 0, -2>, 0
        pigment {spiral1 1 color_map{[0 Red]
                                     [0.5 Red]
                                     [0.5 White]
                                     [1 White]}
                frequency 2
                scale <1, 1, 4>
                translate <0, 0, -2>}
      rotate <90, 180, 0>
//End of Pov-code~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
ReVerSi
Date: 15 Oct 1998 05:45:36
Message: <3625b630.0@news.povray.org>
Umm, just a thought here: how about the pigment patterns spiral1 or spiral2?
cylinder {-1*y,1*y,1 pigment { spiral1 2 color_map { //2 here is arm #
         [0,.5 color red 1 color red 1]
         [.5,1 color rgbf 1 color rgbf 1]
         } rotate 90*x} //note rotation here, starts in z-axis
cylinder {-1*y,1*y,.99 pigment { rgb 1}}
This is applicable to cone too.
Message <36240543.D98C59D4@flash.net>, Dan Connelly  typed...
>From textures.inc :
>pigment {
>    gradient x+y
>    color_map {
>        [0.25 rgb <1,0,0>]
>        [0.25 rgb <1,1,1>]
>        [0.75 rgb <1,1,1>]
>        [0.75 rgb <1,0,0>]
>stripes.
>mapping.
>Dan
>> Ken
>> > same
>> > they're
>> > -JamesF.
  http://members.aol.com/inversez/POVring.html
=Bob
Date: 15 Oct 1998 07:17:22
Message: <3625CB95.9B673005@flash.net>
You are correct, of course....
I really flubbed that one -- I even used this technique to
render tape on a baseball bat a few months ago.  When I reread
the spiral1 doc entry, though, I was confused about how
it extended into 3d.  Anyway, spiral1 it is...
Dan
