POV-Ray : Newsgroups : povray.general : Render Farm for POV-Ray Server Time
14 Oct 2024 02:16:08 EDT (-0400)
  Render Farm for POV-Ray (Message 1 to 3 of 3)
Subject: Render Farm for POV-Ray
Date: 23 Sep 1998 01:05:31
Message: <36087367.E608156B@dorm40.sdsmt.edu>
A couple of friends and I have decided to write some render farm
software for POV-Ray for our senior design project. Our current design
specs are to process animation only. The software is a proposed
client/server application. The server will initially designed to run
under linux and the client to run under Windows 95/98/NT.
Basically it should work like this. Clients connect to the server via
TCP/IP. A client sends the server the a POV src/ini files. The server
then tells each client to render a frame. This continues until all
frames are done. All frames are then uploaded to the server where they
can be downloaded. There are a lot of design guts we need to work out
before we start, but that should be how it is going to work.
I would appreciate all comments on this project. Any functionality that
anyone would like added, security concerns with the uploading of files,
etc. I have begun prototyping the client and I will post that at a later
date. I do not believe that we will implement PVM or PVM style stuff
because of time constraints. Sorry
I do have some questions about the GUI-Ext. I believe that we will
implement GUI-Ext in this application. If anyone has any insight on
GUI-Ext, documentation on the functions, or anything that may be
helpfully, I would appreciate it if they would share them with me. I
have read all the post to this news server about GUI-Ext already,
anything else would be cool.  I also think it would be great if the
Render Farm could set the render priority of POV-Ray. How do I contact
the POV-Ray team about possibly letting us do this?
ryan
Subject: Re: Render Farm for POV-Ray
Date: 23 Sep 1998 11:51:47
Message: <36090b03.0@news.povray.org>
In article <36087367.E608156B@dorm40.sdsmt.edu> , Ryan Hagelstrom
<rya### [at] dorm40sdsmtedu>  wrote:
>How do I contact the POV-Ray team
Read the documentation (the FULL, slightly revised LEGAL DOCS are in there as well)!
There you will find a section for contacting the authors, contact the POV-Ray team
coordinator:
Chris Young, 767### [at] compuservecom
Thorsten
Date: 26 Jul 1999 16:37:40
Message: <379CC70E.7B66A070@crak.com>
Check out our web site at http://www.crak.com
We are running pvmpov and it is incredibly fast.
PVM is fairly easy to install and use.  I would definately look into it
if I were you.
JK
> ryan
CRAK Software (Password Recovery Software)
Http://www.crak.com
joh### [at] crakcom
602 863 9274 or 1 800 505 2725 In the USA
