POV-Ray : Newsgroups : povray.general : Concrete slabs Server Time
27 May 2026 13:54:48 EDT (-0400)
  Concrete slabs (Message 1 to 4 of 4)
Subject: Concrete slabs
Date: 17 Aug 1998 22:07:26
Message: <35d8d3ce.0@news.povray.org>
I am currently working on a scene featuring some kind of a futuristic subway
tunnel. I want to have concrete slabs that make up the floor (and the
walls?) of the tunnel (where the rails are...later on). Can anyone suggest a
realistic way to model these (objects and textures ), and possibly some
cracks in the concrete and between the slabs? Also, any good way to make a
nice-looking riveted metal plate without a bump_map (it's cheating, really)?
You know, the kind you see on sci-fi movies, with many pieces riveted
together. Lastly, any idea what the cross-section of a subway rail looks
like? Here in Sofia we've had subway for about a year now but I've never
used it nor seen it...
Thanks in advance.
Peter
pet### [at] usanet
Subject: Re: Concrete slabs
Date: 17 Aug 1998 22:12:44
Message: <35D8C6AF.93DB8CE0@pacbell.net>
> Thanks in advance.
> Peter
> pet### [at] usanet
  Here are a couple of textures I use for concrete. Use them if you wish.
 #declare Concrete =
   texture { pigment { granite turbulence 1.5 color_map {
    [0  .25 color White color Gray75] [.25  .5 color White color Gray75]
    [.5 .75 color White color Gray75] [.75 1.1 color White color Gray75]}}
    finish { ambient 0.2 diffuse 0.3 crand 0.03 reflection 0 } normal {
    dents .5 scale .5 }}
   #declare Concrete1 =
    [0  .25 color White color Gray95] [.25  .5 color White color White]
    [.5 .75 color White color White] [.75 1.1 color White color Gray85]}}
    finish { ambient 0.2 diffuse 0.3 crand 0.003 reflection 0 } normal {
Date: 18 Aug 1998 01:28:31
Message: <35d902ef.0@news.povray.org>
Thanks!
BTW, are these from the 1000+ textures you once mentioned in the newsgroup
(regarding a texture utility, as far as I remember) ?
Date: 18 Aug 1998 05:26:11
Message: <35D92C3C.AD869B36@pacbell.net>
Yes
Peter Popov wrote:
> Thanks!
