POV-Ray : Newsgroups : povray.general : Broken "difference"? Server Time
13 Jan 2026 04:38:31 EST (-0500)
  Broken "difference"? (Message 1 to 3 of 3)
Subject: Broken "difference"?
Date: 28 Aug 1998 17:13:31
Message: <35E70F95.6AA9@see_signature.com>
I'm trying to take the difference of two objects in Povray 3.02 for
win32, and it just seems broken.
  Here's a simple example:
difference{
           box{<-5.5,2.5,Thickness>,<-3.0,-4,0>
               pigment {color Silver}
               rotate 30*-z
           box{
               <-4.5,1.5,Thickness>,<0,-1.5,0>
  Union and merge both work as documented, but when I try a difference,
I will get the entirety of one object, and nothing of the other, even
though they do intersect.  Is it borken, or is there something that I
just don't understand?
steve
Domain name for replying is "inconnect".
Subject: Re: Broken "difference"?
Date: 28 Aug 1998 17:48:32
Message: <35e717a0.0@news.povray.org>
On Fri, 28 Aug 1998 14:14:13 -0600, NerveGas
A little of both. Your boxes occupy the same space at the same time (the
"coincident surfaces" problem.)  POV traditionally has a hard time figuring
out what you want to do when this happens, because it needs to know which
faces are "inside" the other box and which aren't, but one on the surface is
technically neither inside nor outside.  Try this:
difference{
               rotate 30*-z
           box{
               <-4.5,1.5,Thickness+.001>,<0,-1.5,-.001>
Date: 28 Aug 1998 17:49:11
Message: <35E70955.C4364D9@pacbell.net>
> difference{
>  box{<-5.5,2.5,Thickness>,<-3.0,-4,0> pigment {color Silver} rotate 30*-z }
>  box{<-4.5,1.5,Thickness>,<0,-1.5,0>  pigment {color Silver}}}
> steve
It took me a couple of minutes to notice it but I think
I see your problem. The first box is not built at xyz*0.
Then a rotation has been applied to it. It's no longer where
you expect it to be and the 2 boxes are not touching.
I haven't tested this theory and I may be full of ____
but it seems plausible.
K.Tyler
