POV-Ray : Newsgroups : povray.general : Applying an image map to a transparent object Server Time
27 May 2026 15:17:07 EDT (-0400)
  Applying an image map to a transparent object (Message 1 to 3 of 3)
Subject: Applying an image map to a transparent object
Date: 4 Aug 1998 19:20:37
Message: <35C77A10.49EB4250@intelligencia.com>
I have designed a "wide-mouth mayonnaise jar" CSG object which looks as
good as I can get it.
Now when I go about applying an image map to one of the CSG components,
using 3.1 beta 5 for Windows, I do not see the image. Instead it comes
out black. Alpha channel transparency at least works.
I use a color of "rgbf <1.0, 1.0, 1.0, 0.9>" for all the CSG objects,
but the image map seems to reset the color to "rgbf <1.0, 1.0, 1.0,
1.0>". The option "transmit all 0.9" doesn't seem to help.
Here is the file in question:
#include "glass.inc"
// Glop jar file.
#declare Glop_Jar2 = difference {
   merge {
      // The main body.
      cylinder {
         < 0.000,  0.150, 0>,
         < 0.000,  1.000, 0>,
         0.500
               image_map {
                  png "glop3.png"
                  map_type 2
                  once
            finish { F_Glass1 }
            scale <1, 0.85, 1>
            translate 0.150 * y
            rotate -90 * y
      // The curve along the bottom.
      torus {
         0.350, 0.150
         translate 0.15 * y
      // The bottom piece.
      cylinder {
         < 0.000,  0.000, 0>,
         < 0.000,  0.150, 0>,
         0.350
      // The taper.
      cone {
         < 0.000,  1.000, 0>,
         0.500,
         < 0.000,  1.400, 0>,
         0.400
      // The jar lid thread.
      cylinder {
         < 0.000,  1.400, 0>,
         < 0.000,  1.625, 0>,
         0.400
      // The jar lid stop.
      torus {
         0.400, 0.025
         translate 1.45 * y
   sphere {
      <0.000, -0.500, 0.000>,
      0.600
   union {
      // We need to get an inner curve too.
      sphere {
         < 0.000,  0.200, 0>,
         0.450
         scale <1.0, 0.05 / 0.45, 1.0>
      // The main body.
      cylinder {
         < 0.000,  0.200, 0>,
         < 0.000,  0.975, 0>,
         0.450
      // The taper.
      cone {
         < 0.000,  0.975, 0>,
         0.450,
         < 0.000,  1.375, 0>,
         0.350
      // The jar lid section.
      cylinder {
         < 0.000,  1.375, 0>,
         < 0.000,  1.625, 0>,
         0.350
   interior { I_Glass }
         color rgbf <1.0, 1.0, 1.0, 0.9>
      finish { F_Glass1 }
   translate -0.8125 * y
   scale 2
// end code
The PNG files can be made available on request.
Curtis R. Anderson, Co-creator of "Gleepy the Hen", SP 2.5?, KoX
http://www.servtech.com/~cra/         | Welcome to Gnu-EMACS:
ftp://ftp.servtech.com/pub/users/cra/ |  Press BACKSPACE For Help
mailto:gle### [at] intelligenciacom       | (insert Yiddish words here)
Subject: Re: Applying an image map to a transparent object
Date: 5 Aug 1998 01:52:19
Message: <35C7E507.EF06320D@dhol.com>
The problem is in the finish.  F_Glass1 sets ambient and diffuse to 0.
This kills the image map.  All you need to do is replace the finish
statement on the image mapped part with:
finish {
specular 1
roughness .001
reflection 0.1 }
These are the settings of F_Glass1 without the offending ambient and
diffuse statements.  F_Glass1 is ok for the non-image mapped part.  This
worked well for me.  BTW, you need the interior {I_Glass} statement in
the non-image mapped part as well.
Jerry Anning
cle### [at] dholcom
Date: 6 Aug 1998 00:57:15
Message: <35C92998.7C63DE43@intelligencia.com>
> finish {
> specular 1
> roughness .001
> reflection 0.1 }
I will give that a try. (Maybe something to that effect can be put in
the manual...?)
