POV-Ray : Newsgroups : povray.general : 3D-Scan Server Time
22 Dec 2025 09:04:40 EST (-0500)
  3D-Scan (Message 1 to 10 of 11)
Subject: 3D-Scan
Date: 19 May 1998 04:31:37
Message: <35614367.4C944DF7@stud3.tuwien.ac.at>
Does anyone out there know where I can make a 3D-San of my self and
maybe of some of my friends!
                            ALIL
Subject: Re: 3D-Scan
Date: 19 May 1998 06:40:01
Message: <01bd8312$6ccf0b00$043363c3@mrbcomp>
Wow... even if this was possible (though I can't imagine how it could be
done very accurately... lasers perhaps?) I would assume such a thing would
be very expensive - even if you could find somewhere that would do it...
All I can recommend is you get someone with good spatch/moray modeling
skills... ;)
Matt
ALIL <e9725415@stud3.tuwien.ac.at> wrote in article
<35614367.4C944DF7@stud3.tuwien.ac.at>...
>                             ALIL
Date: 19 May 1998 17:44:59
Message: <6jsuir$cgd$1@oz.aussie.org>
There are plently of laser scanners out there at the moment.  The problem
you've got to watch is the incredible amout of data they produce (hundreds
of megs).  The other way is sound which is very unreliable and the other is
generally magnetic.  There is also the Microscribe by Immersion, I hear it's
very good.
Lance Birch
Remove the smiley to e-mail.
http://www1.tpgi.com.au/users/ambient/lance
Date: 19 May 1998 17:51:03
Message: <6jsunm$ch7$1@oz.aussie.org>
Why not use a 2D photo and use it as a heightfield??
Mike
Lance Birch <:-)Lan### [at] tpgicomau> wrote in message
<6jsuir$cgd$1@oz.aussie.org>...
it's
>very good.
>Lance Birch
Date: 20 May 1998 03:39:03
Message: <6ju1cr$duh$1@oz.aussie.org>
Because there's no way of rotating it and it looking good.  The only way to
get a real model of real 3D geometry is to capture it in some way to measure
depth and angles.  For instance, the laser method uses a laser to cast a
sharp line along the object(s)'(s) surface and then input video in infared
and deciphers the line's shape and distance to create the 3D geometry.
Highfields just aren't good enough for complex models.
Lance Birch
Date: 20 May 1998 04:31:26
Message: <356294DD.6C81@pecos.n.o-s.p.a.m.de>
> Mike
'Cause the brightness in a photograph is not proportional
to the 'height' at that point. And vice versa: That's why
real heightfields of, say, faces actually don't look very
realistic.
-Hans-
Remove n.o-s.p.a.m. to obtain my real address.
In seeking the unattainable,
simplicity only gets in the way.
-- ACM SIGPLAN Sept. 1982
Date: 20 May 1998 05:27:36
Message: <01bd83d1$77473200$253063c3@mrbcomp>
These things really exist? For the public?
Cool.. well, in that case I apologise for the ignorance of my last post ;)
Technology eh?
Matt
Lance Birch <:-)Lan### [at] tpgicomau> wrote in article
(hundreds
is
it's
> very good.
> Lance Birch
Date: 20 May 1998 15:27:38
Message: <01bd8425$491967a0$8a02a8c0@ljr.sbscorp.com>
There are progams available that will let you create your 3D model using
two or more photos taken at differient angles from a known distance (that's
how the dem files are created from satellite photos).
Lloyd
Mike Weber <xmw### [at] racal-pelagoscomx> wrote in article
<6jsunm$ch7$1@oz.aussie.org>...
> Mike
Date: 20 May 1998 17:34:28
Message: <6jvib8$gga$1@oz.aussie.org>
Yeah, I couldn't beleive it when I first heard about it.  They can actually
use ultrasonic sound waves to triangulate the position!
Or magnetic imagers!  It all sounds like SF!
Have you seen what they've done now but, IT'S INCREDIBLE!  Instead of an
ultrasound, you can get a density model of your baby.  Yep, you can actually
see a 3D model of your baby on a computer and rotate and look at it in 3D
space before it's even born!
Lance Birch
Date: 23 May 1998 02:14:00
Message: <01bd8611$b96964e0$0e2b04d1@davidrey>
The two programs I know of that can do this are:
3D Builder
and PhotoModeler.
I think both are in the $600-$800 range.
Lloyd J Robinson, Jr <ljr### [at] sbscorpcom> wrote in article
<01bd8425$491967a0$8a02a8c0@ljr.sbscorp.com>...
(that's
> Lloyd
