POV-Ray : Newsgroups : povray.general : dda_traversal() error on large renders Server Time
29 Mar 2026 20:06:58 EDT (-0400)
  dda_traversal() error on large renders (Message 1 to 3 of 3)
Subject: dda_traversal() error on large renders
Date: 6 May 1998 13:51:28
Message: <3550A320.AAA9B59@cisco.com>
When rendering at high resolutions (4200x3000 and 8400x6000), I keep
getting:
	Illegal grid value in dda_traversal()
This is POV-Ray 3.0 for Windows. The image seems to come out fine, and
the errors don't start until a ways into the image (it seems to vary),
but I get a lot of these messages to the console. Like I said, the image
itself seems fine, so I thought it might be a display routine, so I
tried turning off the render window (which I should have done a long
time
ago anyway...), but I still get the errors.
Is POV-Ray running out of memory at some point? I couldn't find any
memory limitations in the docs, and I couldn't find any reference to
this
error message anywhere. Is there a limitation on image size?
Thanks,
Rob
Rob Napier        | Vote "Linus Torvalds: Builder of the Century"
rna### [at] ciscocom |    http://www.employees.org/~rnapier/linus.html
Wow, I'm being shot at from both sides.  That means I *must* be right.
	    -- Larry Wall in <199### [at] wallorg>
Subject: Re: dda_traversal() error on large renders
Date: 6 May 1998 15:10:54
Message: <3550B5BE.2310DDEC@dhol.com>
> getting:
<snip>
No limitation as such.  In a
not-completely-accurate-but-close-enough-for-jazz nutshell, under the
right circumstances floating point accuracy limits can put "cracks" in
the triangulation of height fields.  You get that message when a ray
hits a crack.  You may or may not get visible artifacts.  I know of no
real cure now, but sometimes slight alterations in camera placement
and/or viewpoint can help.
Jerry Anning
cle### [at] dholcom
Date: 6 May 1998 21:39:21
Message: <01bd7959$3354fd20$557a89d0@reboot>
I've seen that happen, and in each case I was able to cure it by moving the
camera by a small fraction.
--Gary.
Rob Napier <rna### [at] ciscocom> wrote in article
<355### [at] ciscocom>...
> getting:
> time
