POV-Ray : Newsgroups : povray.general : Re: Animated Explosions. Server Time
14 Oct 2024 16:19:37 EDT (-0400)
  Re: Animated Explosions. (Message 1 to 1 of 1)
Subject: Re: Animated Explosions.
Date: 6 May 1998 06:49:13
Message: <35504028.BE83827E@stud3.tuwien.ac.at>
Joshua Boyd wrote:
> Mark Martin wrote:
> >         You might try multiple "fireballs" (halos I assume), and also use the
> > phase modifier to make your color_map or texture change. Since your
> > animation is not looping you could also make the turbulence modifier
> > dynamic in time.  After you get this looking great, do your scaling... I
> > hope you find this helpful.
> Could you provide a short example of makeing the two perams dynmic in
> time?  Do you just use a clock variable there?
 You could youse a linear funktion for phase modifier overlayd with a few cos or
sin-funktions with smal amplitudes to get a fuzzy loking!
        ALIL
