POV-Ray : Newsgroups : povray.general : DEM2POV Problem? Server Time
18 Feb 2025 17:34:38 EST (-0500)
  DEM2POV Problem? (Message 1 to 2 of 2)
Subject: DEM2POV Problem?
Date: 17 Apr 1998 05:05:21
Message: <35371B50.33923C1E@student.canberra.edu.au>
I have been trying to use DEM data for Eastern Australia found at
http://edcwww.cr.usgs.gov/landdaac/gtopo30/gtopo30.html.  Unfortunately
all
the dem2tga & dem2pov converter's do not seem to like it.
Would anyone be able to:
a) direct me to alternate Oz data,
b) direct me to a converter that will work, or
c) tell me where I am going wrong. Below is a summary of the process I
am now
using and the error messages. (It appears the DEM file type is
incompatible?)
Any help would be greatly appreciated.
Roger.
1) Download e140s10.tar.
2) Use dos TAR extraction utility called untgz (by Tillmann Steinbrecher
found at
http://www.isjm.com/tst/untgz.htm) to extract *.dem file.
3)Use dem2tga (by Jon Larimer at http://www.alltel.net/~jonl/dem.html)
and get the following ouput:
D:\temp\dem2tga>dem2tga e140s10.dem my.tga
dem2tga v1.0 (c) 1997 Jon Larimer
This program is public domain.
Quad name field:
Exiting due to signal SIGSEGV
General Protection Fault at eip=000016a1
eax=00000000 ebx=00000000 ecx=00000000 edx=00000000 esi=0004f120
edi=0004dac4
ebp=f1d8f1d8 esp=0004da06 program=D:\TEMP\DEM2TGA\DEM2TGA.EXE
cs: sel=00af  base=82a70000  limit=0005ffff
ds: sel=00b7  base=82a70000  limit=0005ffff
es: sel=00b7  base=82a70000  limit=0005ffff
fs: sel=0087  base=0000ecc0  limit=0000ffff
gs: sel=00c7  base=00000000  limit=ffffffff
ss: sel=00b7  base=82a70000  limit=0005ffff
Call frame traceback EIPs:
  0x000016a1
5)I have tried the DEM2POV utility found at The Povray HomePage.
It causes a gpf after the following output.
D:\temp\dem2pov>dem2pov e140s10.dem my.tga
DEM to POV height-field v1.1c by W. D. Kirby 4/18/95
  based on DEM to x,y,z ascii file, ver 3.1, 1-95 -- Sol Katz, BLM
Map label:
[ 2] DEMlevel:  0
[ 3] elevation Pattern: 0  (=>?0?   )
[ 4] planimetric reference system: 0 (=>georgraphic)
 [ 5] ground Zone: 0
[ 6] proj:       0.0000000       0.0000000       0.0000000
[ 7] plane Unit Of Measure: 0 (=>radians )
[ 8] elevation measurement units code: 0 (=>?0?   )
[ 9] polygon Sides: 0
[10] ground coordinates
     NW (       0.00000,        0.00000)  NE (       0.00000,
0.00000)
     SW (       0.00000,        0.00000)  SE (       0.00000,
0.00000)
[11] Elev. Min:         0.00000, Max:         0.00000, Accuracy code: 0
[14] Spatial Resolution:         0.00000,         0.00000,
0.00000
[15] map size is 0 x 0 (row x columns)
Subject: Re: DEM2POV Problem?
Date: 20 Apr 1998 11:47:32
Message: <353B6E14.F5058084@its.bldrdoc.gov>
> all
> am now
> incompatible?)
GTOPO30 is a binary format, not DEM format. Consequently, neither of
the two programs you mention will work with it. The GTOPO30 archive file
should contain a text file explaining the file format. It isn't too hard
to write a small program to convert it to a TGA file and use it as a
heightfield.
|               Tim Riley                 |
| Institute for Telecommunication Science |
|     National Telecommunications and     |
|       Information Administration        |
|          US Dept. of Commerce           |
|            Boulder, Colorado            |
|      E-mail:tri### [at] itsbldrdocgov      |
|     Per favore spenga le Sue scarpe     |
|  davanti abbandonare il nave spaziale.  |
