POV-Ray : Newsgroups : povray.general : Anyone having problems with 3.1g & Win 2000 Server Time
24 Apr 2026 21:06:39 EDT (-0400)
  Anyone having problems with 3.1g & Win 2000 (Message 1 to 6 of 6)
Subject: Anyone having problems with 3.1g & Win 2000
Date: 24 Feb 2001 19:40:06
Message: <20lg9t0frf8rc9p1p06hpsli33olnaje56@4ax.com>
All,
3.1g used to work on my machine with 98 but under 2000 it bluescreens
my machine when I render "larger" images.  It crashes the machine
about half way through the rendering.
Anyone seen these symptoms?
TIA,
Subject: Re: Anyone having problems with 3.1g & Win 2000
Date: 24 Feb 2001 22:43:33
Message: <3a987f65@news.povray.org>
In article <20lg9t0frf8rc9p1p06hpsli33olnaje56@4ax.com> ,
If your system crashes you most likely have a defective installation of
Windows 2000.  If reinstalling alone does not help, updating your
drivers might help.  The fact that only (?) POV-Ray crashes your system
is just coincidence - in general if your system crashes this is an
indication of a system malfunction, not a problem with the program that
was running when the system crash occurred (there are exceptions to
this, of course).
You can be sure that if there were general problems/crashes running
POV-Ray under Windows 2000, there would be a lot of complaints here
already :-)
     Thorsten
Date: 25 Feb 2001 00:17:09
Message: <3a989555@news.povray.org>
I've had no trouble with images up to 1200 x 800. How large are your files?
Can't image it is Win 2000 by itself..
d..
<nob### [at] yahoocom> wrote in message
news:20lg9t0frf8rc9p1p06hpsli33olnaje56@4ax.com...
> All,
> TIA,
Date: 25 Feb 2001 05:11:58
Message: <3a98da6e@news.povray.org>
Does it still do this with preview turned off ?
I can tell you now that nothing that POV can do will make Windows 2000
crash in the absence of a bug in either W2K or one of the drivers you
have installed (e.g. video). This is because POV is a purely user-mode
(i.e. ring 3) application and is incapable, by itself, of doing anything
'bad' to the OS (unless, as mentioned above, it is triggering an OS bug).
I suspect that you will eventually find that the problem is in one of
your device drivers.
-- Chris
Date: 25 Feb 2001 07:58:37
Message: <3a99017d@news.povray.org>
There is a service pack out for Win 2k already which does address some
application compatability issues. It can be downloaded or ordered on CD
http://www.microsoft.com/windows2000/downloads/recommended/sp1/default.asp
Quoting microsoft, "Service Pack 1 (SP1) provides the latest updates to the
Windows 2000 family of operating systems. These updates are a collection of
fixes in the following areas: setup, application compatibility, operating
system reliability, and security.".
It's not small - about 14 Meg.
Hope this helps.
Duncan Gray
(warning: may contain traces of nut)
Date: 25 Feb 2001 09:14:59
Message: <em4i9t0g89o9nhebo077c7di55aj0ro4ig@4ax.com>
Thanks for all the input guys.  I have been using POV-Ray for many
years now and this is driving me crazy.  I agree with each of you that
it is probably my machine because POV still works fine at work under
2000.  I will keep poking around to see what I can find.
Thanks,
Richard
On Sun, 25 Feb 2001 13:03:50 -0000, "Duncan Gray"
>from:
>Hope this helps.
