POV-Ray : Newsgroups : povray.general : 3.5 and text warning Server Time
22 Apr 2026 05:09:34 EDT (-0400)
  3.5 and text warning (Message 1 to 4 of 4)
Subject: 3.5 and text warning
Date: 22 Nov 2002 14:49:04
Message: <20021122114904.18ca9e72.mathog@caltech.edu>
Some povray files that used to work under 3.1 generate this warning
under 3.5.
"Warning:  Text may not be displayed as expected."
and a reference to changes in 3.5.  But I couldn't figure out which
of the changes listed was responsible.  Here is an example a text
construct which elicits such a warning (this may wrap):
   text{ttf "timrom.ttf", "TYR86 OH",0.0,0.0
     texture{ pigment{ colour red 1.00 green 1.00 blue 1.00 }finish{ LABEL_FINISH }}
     scale<   2.355,   2.355,   2.355>
     translate <   1.178,  -1.178,0>
     matrix <
        1.0000,    0.0000,    0.0000,
        0.0000,    1.0000,    0.0000,
        0.0000,    0.0000,    1.0000,
       -4.6193,  -23.1005,    6.4401
where LABEL_FINISH was declared far above with:
#declare LABEL_FINISH = finish {specular 1 roughness 0.001} ;
Please enlighten me - which part of this is triggering the warning?
Thanks,
David Mathog
mat### [at] caltechedu
Manager, Sequence Analysis Facility, Biology Division, Caltech
Subject: Re: 3.5 and text warning
Date: 22 Nov 2002 15:52:18
Message: <3dde9902$1@news.povray.org>
In article <200### [at] caltechedu> , David Mathog
You set a version lower than 3.5 in your scene.
    Thorsten
e-mail: tho### [at] trfde
Date: 22 Nov 2002 18:01:58
Message: <20021122150157.75f3a4a9.mathog@caltech.edu>
On Fri, 22 Nov 2002 21:52:19 +0100
Huh?
Are you saying that text statements will trigger that warning
whenever version is set to 3.1?   Ok, but presumably there must then
be some cases where text statements render differently in 3.5 than they
did in 3.1.  What are these cases???
We have to set version=3.1 because most of the povray script comes
from a program I cannot modify (distributed as binaries) which emits
code for that version.
Thanks
David Mathog
Date: 23 Nov 2002 05:30:52
Message: <3ddf58dc@news.povray.org>
If you use non-ASCII charcaters or non-text fonts.
    Thorsten
