POV-Ray : Newsgroups : povray.general : PovRay Google Trends Server Time
18 May 2024 19:17:31 EDT (-0400)
  PovRay Google Trends (Message 21 to 30 of 126)
Subject: Re: PovRay Google Trends
Date: 12 Nov 2016 11:20:01
Message: <web.582740ab5604f237a3e03fe0@news.povray.org>
Stephen <mca### [at] aolcom> wrote:
> You will need to join the end of the Queue. :)
> Thomas is working with me. So don't distract him. :P
> Regards
>      Stephen
o.k. I am the last to welcome Thomas to. :))))))))))
But Thomas should know that I signed to him to the reception. :)))
Date: 12 Nov 2016 18:16:47
Message: <5827a2df$1@news.povray.org>
On 11/7/2016 6:51 PM, [GDS|Enropy] wrote:
> Hello,
> As a result of a different discussion, I used Google Trends to track
> searches for Pov since 2004.
> What I found is sad, but I think I found a ray of hope (d'oh..pun).
> Since 2004, searches for (pov ray and pov-ray) have practically dropped
> orders of magnitude:
> https://www.google.com/trends/explore?date=all&q=pov-ray,pov%20ray
> Searches for (povray) are worse:
> https://www.google.com/trends/explore?date=all&q=pov-ray,pov%20ray,povray
> Here is povray vs blender and sketch up:
https://www.google.com/trends/explore?date=all&q=pov-ray,blender%203d,pov%20ray,sketchup
> I found that the interest in Pov seems highly localized, whereas blender
> and sketchup are more widely spread.
> What is this hope of which I speak?
> Well, SketchUp is apparently MADLY popular, and there is a plugin called
> SU2POV which allows interop.
> I didn't even know it existed until I specifically searched for a Sketchup
> plugin for Pov...so I think if that plugin could be improved, and sketchup
> users here and elsewhere did a bit of old-school mid 90's software
> evangelism...Pov might just get a good influx of new blood.
> This would need to be done most especially by those speaking other
> languages, due to the highly localized interest in Pov vs sketchup.
> Does anyone else have thoughts about this? Strategies?
> Ian
The main reasons I use POV-Ray are because it's free, and because I'm
too lazy to learn Blender. My 2 cents.
Mike
Date: 12 Nov 2016 23:01:33
Message: <5827e59d$1@news.povray.org>
Thomas de Groot wrote:
> Ah! There it is! This has been indeed one of the major complaints:
> people (outside of POV-Ray) do not want to create using text editors
> (any more).
I Do Not Fingerpaint.
I Do Not Use Software That Expects Me To Fingerpaint.
I Am A Grownup.  I Can Read And Write.  I Can Do Math.
Reading And Writing And Math Are Accurate.  Fingerpainting Is Guesswork.
  I Like Accuracy.  I Do Not Like Guesswork.
I Like Reading And Writing.  I Like Doing Math.  I Want To Read And
Write And Do Math.  I Do Not Want To Fingerpaint.
And that's why I do POV-Ray.*  :)
--Sherry Shaw
* Oh, and also because it is awesome.
#macro T(E,N)sphere{x,.4rotate z*E*60translate y*N pigment{wrinkles scale
.3}finish{ambient 1}}#end#local I=0;#while(I<5)T(I,1)T(1-I,-1)#local I=I+
1;#end camera{location-5*z}plane{z,37 pigment{granite color_map{[.7rgb 0]
[1rgb 1]}}finish{ambient 2}}//                                   TenMoons
Date: 13 Nov 2016 02:59:30
Message: <58281d62$1@news.povray.org>
>> Regards
>>      Stephen
Oh, right! I shall take the back door to avoid the queue and the press ;-)
I think I shall pass the hot potato to Stephen; after all, he is the
animation expert. I am not good at it...
Date: 13 Nov 2016 03:07:25
Message: <58281f3d$1@news.povray.org>
>> (any more).
> --Sherry Shaw
Absolutely! Although, me, I am not very good at math, so I mix POV-Ray
with a bit of fingerpainting.
[blush][small print] I like fingerpainting [/small print][/blush]
Date: 13 Nov 2016 03:17:35
Message: <5828219f$1@news.povray.org>
>>> Regards
>>>      Stephen
But I will be trying to learn blender so I am disqualified.
Shame about that. :)
Regards
Date: 13 Nov 2016 03:34:18
Message: <5828258a$1@news.povray.org>
>>> (any more).
>> --Sherry Shaw
I'm too lazy to do the maths.
Splash a bit here smudge a bit there. That's the way to do it!
Does the kraken awake?
Because I think LanuHum is right.
<aside> I wonder what the average age of Pov-Ray users is. </aside>
Regards
Date: 13 Nov 2016 03:37:43
Message: <58282657$1@news.povray.org>
>>>> (any more).
>>> --Sherry Shaw
Age? well above average I am sure. So, what to do about it?
Date: 13 Nov 2016 07:06:33
Message: <58285749$1@news.povray.org>
>>>>> (any more).
>>>> Guesswork.
>>>> --Sherry Shaw
What POVRay needs is its own user interface tailored to POVRay. Other
user interfaces tend to break the world into triangles which don't
translate well to POVRay.  The POVRay text files are cumbersome because
they are non-visual and they force you to constantly switch from text
mode to render mode.
I would like to see a user interface that supports all of the POVRay
primitives.  It would allow you select components of the scene with
parameters that are alterable.  You don't necessarily need to see the
text but rather a graphical representation of the text.  It would allow
you to change any parameters and would re-render the scene automatically
with those changes.  The rendering might be incremental - it renders in
low resolution first and refines the image as you wait or renders
without textures then with textures or it renders without reflections
and later adds reflections - just some ideas.
I often find myself asking "What happens if I change this parameter?"
To answer that I need to keep editing and rendering until I understand
it.  I'd rather select the parameter in a UI and use the mouse to change
the value and see in real time what it does to the image.
Thoughts?
David Buck
Date: 13 Nov 2016 07:56:06
Message: <582862e6@news.povray.org>
> I often find myself asking "What happens if I change this parameter?" To
> answer that I need to keep editing and rendering until I understand it.
> I'd rather select the parameter in a UI and use the mouse to change the
> Thoughts?
> David Buck
Yes, I agree with that indeed. That could be something like an enhanced
Moray, could it not? All the more reasons to have Moray dusted off I
believe, but that involves (wo)manpower which I believe the pov-team
lacks at the moment. In the meantime, we - as users - could seriously
assess what exactly we want changed - in Moray, if that is the course to
follow - or implemented in a brand-new interface.
[I think it might be time for me to take Moray down from the 'shelf of
forlorn programs', and start playing again...]
