![](/i/fill.gif) |
Chris wrote:
> Does anybody know where the original sources for the documentation are? I
> keep seeing references to 'makedocs.pl' in the unix source tree
> (docs/*.html), but I can't find either the script or the master
> documentation. Shouldn't it be around somewhere?
If you find references to makedocs.pl in the POV-Ray for Unix
documentation you are using an outdated version of POV-Ray (makedocs.pl
was only used in POV-Ray 3.5).
The program used to generate the html/pdf/etc. version of the docs is
not available so it does not make sense to make available the docs
source files either.
Last updated 23 Sep. 2004 _____./\/^>_*_<^\/\.______
![](/i/fill.gif) |
