3.2.2.6.3
In the #range variety, Low_Value and High_Value are floats separated by a
comma and enclosed in parentheses. If Low_Value <= Switch_Value and
Switch_Value<=High_Value then the condition is true.
Should perhaps be:
If Low_Value >= Switch_Value
Phil Cook
All thoughts and comments are my own unless otherwise stated and I am
happy to be proven wrong.
Phil Cook <phil [at] nospamdeckingdeals co uk> wrote:
> 3.2.2.6.3
> Should perhaps be:
Are you sure?
<1,1,3>hollow}text{ttf"timrom""Warp".1,0translate<-1,-.1,2>}// - Warp -
Phil Cook wrote:
> Should perhaps be:
I've found a very effective way of preventing this sort of error is to
never use > or >=.
A <= B && B <= C means "B is between A and C".
now() < saved() + 15
means if the close is before fifteen minutes after the saved time.
Etc.
And lo on 20 Aug 2004 16:19:20 -0400, Warp <warp [at] tag povray org> did
spake, saying:
>> 3.2.2.6.3
>> a
>> Should perhaps be:
> Are you sure?
Nope :) Perhaps Switch_Value >= Low_Value, sorry it just read wrong to me
in conjuction with the example which goes:
#range (LOW_1,HIGH_1)
// This section is parsed if (VALUE>=LOW_1)&(VALUE<=HIGH_1)
Phil Cook
But why? It's the same thing.
And lo on 22 Aug 2004 12:41:35 -0400, Warp <warp [at] tag povray org> did
spake, saying:
Because the text reads Low_Value <= Switch_Value, Switch_Value<=High_Value
and the example reads the equivalent of Switch_Value >= Low_Value,
Switch_Value <= High_Value. Yes mathematically they are the same but it's
not consistent grammatically.
Phil Cook
