POV-Ray : Newsgroups : povray.documentation.inbuilt : Documentation issues Server Time
27 Mar 2026 06:16:58 EDT (-0400)
  Documentation issues (Message 1 to 5 of 5)
Subject: Documentation issues
Date: 5 Aug 2002 01:34:35
Message: <ja3skusq5l328mf9jbc6bor3nn3ncii827@4ax.com>
Section 6.5.1.5 - is gif still supported?
Section 6.5.4.1
evaluate
POV-Ray can also dynamically adapt the used max_gradient. To activate
this technique you have to specify the evaluate keyword followed by
three parameters:
  P0: the _minimum_ max_gradient in the estimation process,
  P1: an _over-estimated_ max_gradient value, (1 or greater)
  P2: an attenuation parameter (1 or less)
If you are unsure what values to use, start with something like
evaluate 5, 1.2, 0.95.
How is 5 a minimum and 1.2 an over-estimation?
Peter Popov ICQ : 15002700
Subject: Re: Documentation issues
Date: 5 Aug 2002 03:53:06
Message: <3D4E2EE0.32FDCDA4@gmx.de>
The second parameter is an overestimation *factor*, you are right that the
docs are not very clear about that.
Last updated 03 Aug. 2002 _____./\/^>_*_<^\/\.______
Date: 5 Aug 2002 10:20:50
Message: <Xns9261A6F4110Bseed7@povray.org>
> that the docs are not very clear about that.
This has com up before, the docs have been changed.
Ingo
Date: 6 Aug 2002 19:20:14
Message: <3d5059ae@news.povray.org>
  Try it.
Date: 7 Aug 2002 12:42:25
Message: <hdj2luo7d6pd869qu5g6jgmgnilb6qb0mc@4ax.com>
On 6 Aug 2002 19:20:14 -0400, Warp <war### [at] tagpovrayorg> wrote:
>  Try it.
You know... this never occurred to me :)
I will, as soon as I reboot back into XP (playing D2X at the moment)
