POV-Ray : Newsgroups : povray.documentation.inbuilt : dictionary container types Server Time
15 May 2026 02:53:53 EDT (-0400)
  dictionary container types (Message 11 to 19 of 19)
Subject: Re: dictionary container types
Date: 23 Nov 2016 11:43:34
Message: <5835c736$1@news.povray.org>
On 11/23/2016 10:04 AM, clipka wrote:
> The changes to array syntax and behaviour don't fit into the
> "Dictionary" section; they should instead be in the "Array" section.
thanks for keeping me honest:
http://wiki.povray.org/content/Reference_Talk:Array
Date: 23 Nov 2016 12:17:17
Message: <5835cf1d$1@news.povray.org>
Am 23.11.2016 um 17:43 schrieb Jim Holsenback:
I think I got you confused.
The information I provided in the earlier post was for the entire bundle
of changes in the `feature/dictionary` branch currently waiting to be
tested and merged. The branch has grown to become somewhat of a
misnomer, and `feature/containers` would be a more fitting name by now,
as besides introducing the new `dictionary` container type it also
contains improvements to the classic old-school integer-indexed `array`
container.
All the information you put in the numbered-list section starting with
"Array elements will no longer have to be all of the same type [...]"
applies to arrays, not dictionaries.
It's ok (and, if I am asked, desirable) to have the dictionary-related
stuff in a separate section.
Also, typo:
"There has been a Change that removes than restriction."
I'm also noticing right now that the comments in the example section are
a bit inconsistent; please replace "testing" and "removing" with "test"
and "remove".
Date: 23 Nov 2016 13:27:26
Message: <5835df8e@news.povray.org>
no doubt ... back when all this happened i was /not/ following the
goings on, but now i'm finding time to get caught up.
Date: 24 Nov 2016 09:08:01
Message: <5836f441$1@news.povray.org>
lol ... ok enough with the back-and-forth already ;-)
not sure why i kept wanting to treat as two different subjects ...
hopefully i've cleared things up:
http://wiki.povray.org/content/Reference_Talk:Array and we can stick a
fork in this one!
Date: 24 Nov 2016 10:01:33
Message: <583700cd$1@news.povray.org>
Am 24.11.2016 um 15:07 schrieb Jim Holsenback:
> fork in this one!
Almost there.
"Additional points to consider are as follows:"
- Please add a note that this is new in 3.7.1. ;)
- I'd remove the "will" from "1. Array elements will no longer...".
- I'd collapse 1.a and 1.b into a single paragraph.
- I'd collapse 3.b and 3.c into a single paragraph.
- I'm noticing only just now that points 4. and 5. apply only to
dictionaries. I think something should be done to make this clearer.
- I'm noticing only just now that 6. is a duplicate of 4.
- I'd add a few end-of-sentence markers (aka full stops) to the items. ;)
- I'd personally prefer a bullet list, as there's no hierarchy among the
items.
Also, I'd move anything related to dictionary initializers to the "Array
Initializers" section, possibly with a line of text or two.
Date: 25 Nov 2016 07:00:36
Message: <583827e4$1@news.povray.org>
>> fork in this one!
> Almost there.
argh ... you're stifling my creativity ;-)
Date: 13 Dec 2016 04:17:02
Message: <584fbc8e$1@news.povray.org>
Am 22.11.2016 um 08:35 schrieb Mike Horvath:
> On 11/19/2016 7:34 PM, clipka wrote:
>> Am 20.11.2016 um 01:10 schrieb Mike Horvath:
>>> On 11/19/2016 2:26 PM, clipka wrote:
>>>>     // alternative
>>>>     #declare Fnord = dictionary {
>>>>       .Foo: 42,
>>>>       .Bar: sphere { <0,0,0>, 1 }
>>> Will the dotted syntax allow people to use strings like ".declare" or
>>> ".texture"? I don't think it should.
>> No -- just like with variable identifiers, keywords are not allowed
>> there.
> I still think the dot is superfluous.
Think about it:
    #declare Foo = "Dang";
    #declare Bar = "What";
      Foo: 42,
Which of the following would that supposedly be equivalent to?
(A)
    #declare Fnord = dictionary;
    #declare Fnord.Foo = 42;
    #declare Fnord.Bar = sphere { <0,0,0>, 1 }
(B)
    #declare Fnord[Foo] = 42;
    #declare Fnord[Bar] = sphere { <0,0,0>, 1 }
aka
    #declare Fnord.Dang = 42;
    #declare Fnord.What = sphere { <0,0,0>, 1 }
I think mandating the dot is a nice way to prevent such ambiguity; plus,
it makes things a tiny bit more consistent: Whatever you'd normally put
after the dictionary identifier, you just pop it into the initializer.
Date: 13 Dec 2016 05:00:06
Message: <584fc6a6$1@news.povray.org>
Am 13.12.2016 um 10:17 schrieb clipka:
> Think about it:
>       Foo: 42,
To elaborate more on that point: When designing the syntax for
dictionary initializers, one could come up with the following
alternatives to all denote the same:
(Intent)
    #declare Fnord["Foo"] = 42;
    #declare Fnord["Bar"] = sphere { <0,0,0>, 1 }
(A)
      Foo: 42,
(B)
      "Foo": 42,
      "Bar": sphere { <0,0,0>, 1 }
(C)
      .Foo: 42,
(D)
      ["Foo"]: 42,
      ["Bar"]: sphere { <0,0,0>, 1 }
Note how variants (A) and (B) are fundamentally incompatible: If the key
can be a string literal, it is legitimate to also expect other string
expressions to work, and this would include plain references to string
variables. Thus, a consistent implementation of (B) would also allow for
the following:
    #declare Key1="Foo";
    #declare Key2="Bar";
      Key1: 42,
      Key2: sphere { <0,0,0>, 1 }
This however would take on a completely different meaning under variant (A).
Now one could rule in favour of either A or B, and I think both have
their merits. Which is why I think it wise to go for neither of them,
and instead opt for variants that are collision-free not only with
respect to each other, but even with respect to the entire set of
_possible_ alternatives.
Date: 13 Dec 2016 05:43:39
Message: <584fd0db$1@news.povray.org>
Am 13.12.2016 um 11:00 schrieb clipka:
> (A)
>       Foo: 42,
> (C)
>       .Foo: 42,
Here's another case study showing how (A) might be disadvantageous:
    #declare Value = "Bar";
    #declare Fnord.Foo = Value;
In (A) notation, the equivalent would be:
      Foo: Value
But if the identifier `Value` on the right-hand side is evaluated to
"Bar", wouldn't a user also expect, with some legitimacy, the identifier
`Foo` on the left-hand side to be evaluated in the same manner? Thus, a
user may be fooled into expecting the following to work:
    #declare Key = "Foo";
      Key: Value
In (C) notation, it would instead be:
      .Foo: Value
Here, the mandatory dot gives the user a hint that there is /something/
different about the way the two identifiers act.
There's also another, much more far-reaching rationale to pick the dot
notation: Some day or another we'll want to overhaul the entire Scene
Description Language, and replace it with something similar but more
powerful while at the same time much more self-consistent.
One part of the deal would be to demote parameters (such as the
"diffuse" in the "finish" block) from reserved keywords to something
much more akin to "variables". We would also want users to be able to
define their own data structures that behave in exactly the same way, so
that users might e.g. define their own parameterizable geometric shapes.
However, in such a world it could become increasingly difficult to tell
apart parameters from genuine variables - and one possible solution to
that problem might lie in adopting the dot notation for parameters,
while using "undotted" identifiers for variables defined elsewhere; e.g.
a finish definition might end up looking like this:
    finish {
      .diffuse:    rand(R);
      .specular:   1 - .diffuse;
      .reflection: .specular * ReflectionFactor;
Looking familiar? ;)
