POV-Ray : Newsgroups : povray.documentation.inbuilt : Documentation Migration Server Time
9 Jun 2026 05:20:58 EDT (-0400)
  Documentation Migration (Message 11 to 19 of 19)
Subject: Re: Documentation Migration
Date: 22 Jan 2009 06:14:29
Message: <49785515@news.povray.org>
"Eddie" <non### [at] nowherecom> wrote in message
news:4977ec78$1@news.povray.org...
> Jim, I don't know PHP but I suspect you're approaching this the wrong way.
don't think so, perhaps I've not communicated clearly ....
> You don't need to create PHP scripts, you simply need to create one or
> more XML documents with the text of the pages in the WIKI text format.
the PHP scripts are to pull the data back out in various formats .... pdf,
latex, windows (chm) .....
the perl script is to process those pesky pov-centric tags (sectiondesc,
indexentry, linkto) by wrapping them in comments so they are not end user
viewable but are there none the less for PHP script to find them later.
There are also some wiki-isms that I've had to account for. This process is
pretty automated. I'm NOT doing any hand edits with the exception of the TeX
formulas used in the reference. I decided to do that by had as there were
only about a dozen or so used through out  the entire doc set  .... see on
the wiki User:Jholsenback
> You can download a few pages to see what the format looks like:
> http://wiki.povray.org/content/Special:Export
yes I've used this feature to export data from other wiki's into mine
(sandbox) ... it works rather nicely.
> Once they're ready you can e-mail them to an admin like Chris who can
> import them and the pages defined in the XML file(s) will get created.
I have sysop so I can do that myself.
> Let me know if you need more detail.
no offence ... I'm pretty far up on the curve now. I have a clear vision of
where I'm going with this.
Date: 22 Jan 2009 06:21:54
Message: <497856d2@news.povray.org>
"Jim Henderson" <nos### [at] nospamcom> wrote in message
news:497808fa@news.povray.org...
> The challenge isn't just exporting to a format to import to Wiki (what
> you suggest is where I started on it myself), but also to export
> modifications/updates put in the Wiki back into the povdoc format.  If
> you strip the povdoc tags from the file (which seemed to me to be
> necessary to use the xml format), then you can't easily re-insert them
> when you dump the pages again.
not stripped but wrapped in comments ..... wiki processes ALOT of html tags
but not all so I've had to come up with what I consider a wiki equivilant in
a few cases. The input side documents are just html stub files wrapped in a
bit of wiki markup.
> That's why a plugin seems like a better approach.  If the wiki preserves
> those formatting tags, then they can be re-exported.  The tags themselves
> are used for things like linking sections to the TOC and the index.
yes and chm (windows help) indexing, keyword building (for searching) .....
Jim (the other one ;-)
Date: 22 Jan 2009 11:07:41
Message: <497899cd$1@news.povray.org>
> tags but not all so I've had to come up with what I consider a wiki
> equivilant in a few cases. The input side documents are just html stub
> files wrapped in a bit of wiki markup.
That's a good way of handling it.  Cue discussion from p.o-t about the
xkcd cartoon about the guy who got locked out of his apartment and tried
everything except ringing the doorbell to get his roommate's attention....
>> preserves those formatting tags, then they can be re-exported.  The
>> tags themselves are used for things like linking sections to the TOC
>> and the index.
Yep, and those are big ones. :-)
Jim
Date: 22 Jan 2009 13:06:36
Message: <4978b5ac$1@news.povray.org>
news:497899cd$1@news.povray.org...
or locked keys in car but forgot to notice passenger window was down ...
I've had to make some consessions regarding linkto .... on the wiki side
that is, however the orginal intent of the linkto tag has been preserved in
comments.
Ciao
Date: 22 Jan 2009 14:00:30
Message: <4978c24e$1@news.povray.org>
>> tried everything except ringing the doorbell to get his roommate's
>> attention....
Yup.  BTDT - once. :-)
> in comments.
That's good to know. :-)
Jim
Date: 22 Jan 2009 20:34:42
Message: <49791eb2$1@news.povray.org>
"Jim Holsenback" <jho### [at] hotmailcom> wrote in message
news:49785515@news.povray.org...
> of where I'm going with this.
None taken, and none intended.
Glad you're making progress.
Eddie
Date: 23 Jan 2009 12:46:30
Message: <Xns9B9CBEF5E2BCDseed7@news.povray.org>
in news:497347ae@news.povray.org Jim Holsenback wrote:
> Now that the povwiki is backonline I thought I'd let you folks in on
> what I've been up to ....
Jim,
I'm not around here much lately, so I may have missed a few things and
be late with my comment, but I still have an old idea from the time
when I did the docs.
 The basic idea was the same as you're doing now, make the docs
available in a wiki. My look at it was a bit different, as I'm lazy and
don't like all the conversions that have to be done. Then I came across
the MoinMoin Wiki engine http://moinmo.in/ that makes it possible to
use several different parsers for wiki markup. Being a terrible
programmer I never got anything that eats pov-doc as markup. Yet still,
would it be possible to do something like that for the MediaWiki
engine?
Another way could be to abandon the pov-doc format and choose ReST
http://docutils.sourceforge.net/rst.html , the MoinMoin engine can deal
with ReST http://moinmo.in/HelpOnParsers/ReStructuredText and the
python documentation is also written in ReST and then processed with
Sphinx http://sphinx.pocoo.org/ an example of the docs
http://docs.python.org/index.html
ingo
Date: 24 Jan 2009 06:00:18
Message: <497af4c2@news.povray.org>
"ingo" <ing### [at] tagpovrayorg> wrote in message
news:Xns9B9CBEF5E2BCDseed7@news.povray.org...
Ingo,
Thanks for the links. Chris had me looking at a few tools before I decided
to write something on my own.
This whole process has me with eye's wide open now. There sure are alot of
markup languages and parsers out there. Some fairly task specific other
pretty general, and it seemed that the tools I DID look at only offered the
80% solution. That's why I ended up settling on a home grown perl solution.
Again thanks for the links. I'll have a look even if it's only for a bit of
reading between tasks :-)
Date: 31 Jan 2009 10:12:37
Message: <49846a65@news.povray.org>
news:4977076f@news.povray.org...
> I'm very close to having content ready. I think I can get the perl script
> changes and additions (that came from my first run at the data) done
> today.
Some delays but I was able to get the fall out from my first run at the data
integrated into the perl script.
I've had another run at the date and it looks OK fine!
Just for the heck of it I decided to test export/import functionality
between wiki's and I posted the section or chapter table of contents
http://wiki.povray.org/content/Documentation:Contents
Jim
