Whisperings:Solo Piano Radio
  POV-Ray : Newsgroups : povray.documentation.inbuilt : Pov help 3.6.1 Server Time: 22 Nov 2008 06:50:10 GMT
  Pov help 3.6.1 (Message 1 to 6 of 6)
Subject: Pov help 3.6.1
Date: 20 Aug 2004 10:56:53
Message: <opsc01pvcsefp2ch@news.povray.org>
3.2.2.6.3
In the #range variety, Low_Value and High_Value are floats separated by a
comma and enclosed in parentheses. If Low_Value <= Switch_Value and
Switch_Value<=High_Value then the condition is true.
Should perhaps be:
If Low_Value >= Switch_Value
Phil Cook
All thoughts and comments are my own unless otherwise stated and I am
happy to be proven wrong.
Subject: Re: Pov help 3.6.1
Date: 20 Aug 2004 20:19:20
Message: <41265cc8@news.povray.org>
Phil Cook <phil [at] nospamdeckingdealscouk> wrote:
> 3.2.2.6.3
> Should perhaps be:
  Are you sure?
Date: 21 Aug 2004 00:30:02
Message: <4126978a$1@news.povray.org>
Phil Cook wrote:
> Should perhaps be:
I've found a very effective way of preventing this sort of error is to
never use > or >=.
A <= B && B <= C means "B is between A and C".
now() < saved() + 15
means if the close is before fifteen minutes after the saved time.
Etc.
Date: 21 Aug 2004 18:23:33
Message: <opsc3hhji6dzhzpc@news.povray.org>
And lo on 20 Aug 2004 16:19:20 -0400, Warp <warp [at] tagpovrayorg> did
spake, saying:
>> 3.2.2.6.3
>> a
>> Should perhaps be:
>   Are you sure?
Nope :) Perhaps Switch_Value >= Low_Value, sorry it just read wrong to me
in conjuction with the example which goes:
#range (LOW_1,HIGH_1)
    // This section is parsed if (VALUE>=LOW_1)&(VALUE<=HIGH_1)
Phil Cook
Date: 22 Aug 2004 16:41:35
Message: <4128ccbf@news.povray.org>
  But why? It's the same thing.
Date: 23 Aug 2004 08:05:44
Message: <opsc6cbvgoefp2ch@news.povray.org>
And lo on 22 Aug 2004 12:41:35 -0400, Warp <warp [at] tagpovrayorg> did
spake, saying:
Because the text reads Low_Value <= Switch_Value, Switch_Value<=High_Value
and the example reads the equivalent of Switch_Value >= Low_Value,
Switch_Value <= High_Value. Yes mathematically they are the same but it's
not consistent grammatically.
Phil Cook
Copyright 2003-2008 Persistence of Vision Raytracer Pty. Ltd.
