POV-Ray : Newsgroups : povray.bugreports : bump maps inverted in spherical warp Server Time
15 Dec 2025 22:18:43 EST (-0500)
  bump maps inverted in spherical warp (Message 1 to 10 of 15)
Subject: bump maps inverted in spherical warp
Date: 3 Aug 2021 16:25:00
Message: <web.6109a481dc4077061e101ef1b9aee0ac@news.povray.org>
I'm using a normal with a bump map, wrapped around a sphere using
warp{spherical}.  It looks normal in the northern hemisphere, but the bumps are
changed to depressions in the southern.
I've reproduced this on 3.8.0 alpha on Linux, as well as both 3.7 and 3.8 beta
on Macintosh.  Attached is a scene file that reproduces it (bumpmap.pov), along
with the two
bump map images it uses and the resulting image.  The "equator" on the image is
3 rows from the top, so you can see the top 3 rows are correct and the ones
below that are inverted.  (Light is above the camera.)
--paul
Download 'bug.tar.gz' (387 KB)
Subject: Re: bump maps inverted in spherical warp
Date: 4 Aug 2021 03:07:05
Message: <610a3c99$1@news.povray.org>
Am 03.08.2021 um 22:19 schrieb pkoning:
This is a known issue that has been around for... well, ever since
warped bump maps were first introduced, I guess.
Sometimes the bumps even seem to turn "sideways".
Date: 4 Aug 2021 10:25:00
Message: <web.610aa29bfbcfb68e1e101ef1b9aee0ac@news.povray.org>
And sometimes it doesn't happen.  Before today I haven't noticed it, though I
may have overlooked it.  In earlier tests I was using a plain texture instead of
the "cells" pattern, and then I don't remember seeing it.
Just  now I tried to reproduce it but I'm seeing a different baffling issue:
when I take out the "cells" pattern and replace it by a reference to a plain
texture, the parser complains that the "warp" modifier is not expected.  See
attached.
Possible Parse Error: Unmatched {
"/Users/pkoning/Documents/svn/tajemnica/bumpmap.pov"
 line 100
Parse Error: No matching }, warp found instead
Download 'bumpmap.pov.txt' (3 KB)
Date: 5 Aug 2021 02:45:00
Message: <web.610b87ecfbcfb68e4cef624e6e066e29@news.povray.org>
> attached.
>  line 100
Apparently, a warp{...} cannot be added to a previously-#declared texture. I
sometimes run into similar problems; some things can be added, some can't.
Your syntax is like this:
#declare tmoon = texture
  pbfr // [previously-#declared]
  scale <rfeature, rfeature * 2, 1>
  no_bump_scale
  warp {spherical}
Interestingly, the no_bump_scale *is* OK there. I was surprised at that.
Date: 5 Aug 2021 03:30:00
Message: <web.610b930bfbcfb68e4cef624e6e066e29@news.povray.org>
> ...the parser complains that the "warp" modifier is not expected.  See
> attached.
By the way: As Clipka pointed out in a another recent thread, those "unmatched
{" warnings/errors are sometimes 'generic', in that they simply flag some kind
of 'possible' error that isn't clearly known to the parser. Yeah, it's kind of
confusing sometimes, to figure out what the true problem is. ;-)
Date: 5 Aug 2021 05:42:34
Message: <610bb28a$1@news.povray.org>
>> attached.
Actually, the reason this is called "possible error" (my naming back
then) has to do with the message driven changes to output from POV-Ray
3.5 onward. Before, the parser would simply output to a text stream, so
it was perfectly feasible to output some text somewhere and the next
line would make sense out of it (from the user's perspective). However,
there might be a long and complex call chain of internal parser
functions between the place that detected the likely error and the place
that actually knows it is an error.
In modern integrated development environments (IDEs) it is at last
handled much better because the parsers hand them a full trace of all
the steps they took to get where they are and the user gets a kind of
trace where the parser went with each step and what it expected or
allowed. So yes, error reporting evolved over the last 15 years. But it
would require a very well structured parser, which POV-Ray doesn't have
due to its age (and no, it is not easy to rewrite either, nor is it a
beginner's task).
Thorsten
Date: 5 Aug 2021 17:20:00
Message: <web.610c55a0fbcfb68e1e101ef1b9aee0ac@news.povray.org>
> > attached.
> >  line 100
>   no_bump_scale
>   warp {spherical}
Yes, that's documented to affect the texture it is applied to and all its
offspring.
It's strange that warp works the way you mentioned, it makes it very hard to
use.  The fact that it's an undocumented behavior doesn't help.  (I suppose it
makes sense if it's considered a bug -- I think it should be.)
Date: 5 Aug 2021 17:25:00
Message: <web.610c56abfbcfb68e1e101ef1b9aee0ac@news.povray.org>
>   no_bump_scale
>   warp {spherical}
That doesn't seem to be the explanation.  I rewrote it without any declared
identifiers and it still fails:
  pigment { color srgb <0.55 0.60 0.65> }
  finish { moon_finish }
  normal {
    bump_map {
      png "robo-bfr.png"
      bump_size 8e-3 *5
  warp {spherical}
  no_bump_scale
Same message, complaining about the warp.
Date: 5 Aug 2021 18:15:00
Message: <web.610c61cdfbcfb68e1f9dae3025979125@news.povray.org>
Because you have it in the wrong place.
You have a plain srgb pigment - no _pattern_.  So there is nothing to warp.
Move the warp up into the normal statement and it works.
  finish { specular 0.1 }
  normal {
    bump_map {
      png "plasma2.png"
      bump_size 8e-3 *5
    warp {spherical}
  no_bump_scale
Date: 5 Aug 2021 20:20:11
Message: <610c803b$1@news.povray.org>
>    normal {
>      bump_map {
>        png "plasma2.png"
>        bump_size 8e-3 *5
>      warp {spherical}
>    no_bump_scale
I think you've got it Bill. The behavior, though, looks inconsistent to
me. Maybe if I think about it more, it's how it must be?
Looking at something like this:
#version 3.8;
#declare pmoon = pigment {
     color rgb <0.55 0.60 0.65> warp {spherical}
#declare tmoon = texture {
     // pigment { color rgb <0.55 0.60 0.65> warp { spherical } }
         function { 0.5 }
         color_map {
             [ 0 color rgb <0.55 0.60 0.65> ]
             [ 1 color rgb <0.55 0.60 0.65> ]
       //warp {spherical}
     normal {
         bump_map {
             png "plasma2.png"
              bump_size 8e-3 *5
       //warp {spherical}
     warp {spherical} // Parser sees this as illegal
     scale <1, 2, 1>
     no_bump_scale
I get :
File 'hmm.pov' line 7: Possible Parse Error: Unmatched {
File 'hmm.pov' line 26: Parse Error: No matching }, warp found instead
If I comment that last warp{}, and un-comment two warp{}s above - or use
instead the plain pigment inside the texture with the warp{}, I get no
complaint about any 'pointless' warps(a) - though some of them certainly
are.
There are likely situations where top level warps / turbulence could be
applied and passed to contained blocks, but I believe it would be hard
(impossible?) to do generally...
Drifting, the above examples touch on why I find myself sometimes
wanting to be able to declare warp ids.
(a) - Not done any debugging to see if the 'pointless' warps / modifiers
end up used.
Aside 1: turbulence{} trips this parse error too.
Aside 2: transforms can be pointless too and like turbulence and warp we
'sometimes' get PossibleError warnings for those though I'm not aware of
any hard errors there.
Aside 3: With image based mapping, the usual approach would be to use
the appropriate map type inside the bump_map{} block - here 'map_type 1'
spherical - though the warp{spherical} modifier should work too.
Aside 3a: There is too 'uv_mapping' for spheres which can be used inside
texture, pigment and normal blocks.
:-) Nothing if not lots of knobs,  buttons and switches!
Bill P.
