POV-Ray : Newsgroups : povray.bugreports : alpha.10064268 macro problem Server Time
22 Nov 2024 08:55:04 EST (-0500)
  alpha.10064268 macro problem (Message 1 to 10 of 32)
Subject: alpha.10064268 macro problem
Date: 3 Apr 2021 14:40:00
Message: <web.6068b5eea7e9bfcc79819d986cde94f1@news.povray.org>
hi,
I've run into a problem which I cannot understand.  I'm working on a 'Foreach'
macro, to process arrays.  it works as expected, except..
the below shows the error message I'm getting when I try to create an object
from within the "payload" macro; first run displays the values supplied from an
array, with the offending line (208) commented out.
jr@swift:1:$ povparse fore_demo.pov
Persistence of Vision(tm) Ray Tracer Version 3.8.0-alpha.10064268.unofficial
==== [Parsing...] ==========================================================
e[0] = 0  e[1] = 0  e[2] = 'one'  e[3] = 7.
e[0] = 2  e[1] = 1  e[2] = 'two'  e[3] = 6.
e[0] = 4  e[1] = 2  e[2] = 'three'  e[3] = 5.
e[0] = 6  e[1] = 3  e[2] = 'four'  e[3] = 3.
e[0] = 1  e[1] = 4  e[2] = 'five'  e[3] = 2.
e[0] = 3  e[1] = 5  e[2] = 'six'  e[3] = 4.
e[0] = 5  e[1] = 6  e[2] = 'seven'  e[3] = 1.
e[0] = 7  e[1] = 7  e[2] = 'eight'  e[3] = 0.
File 'fore_demo.pov' line 216: Parse Warning: No objects in scene.
==== [Rendering...] ========================================================
Rendered 1024 of 1024 pixels (100%)
POV-Ray finished
jr@swift:2:$ povparse fore_demo.pov
File 'fore_demo.pov' line 199: Parse Error: Expected 'numeric expression',
 sphere found instead
Fatal error in parser: Cannot parse input.
Render failed
zip attached.  (the demo scene is meant to double as draft documentation, hence
the format)
regards, jr.
Download 'foreachbug.zip' (5 KB)
Subject: Re: alpha.10064268 macro problem
Date: 3 Apr 2021 16:35:00
Message: <web.6068d0cd54e5aaba1f9dae3025979125@news.povray.org>
Because it is looking for a numeric expression that you somehow left out.
When I insert a line before the sphere and put "0", I get:
Possible Parse Error: Unmatched (
at File: foreach.inc Line: 344 Col: 11
Parse Error: No matching ), sphere found instead
But then curiously, when I put "0)" I get:
Parse Warning: Unbalanced ) in include file
Parse Warning: Unbalanced } in include file
Parse Error: Unbalanced #end directives in include file.
Other than that, you have too much clever stuff going on for me to follow.
Add in more debug statements to follow your code flow.
I added:
#macro fore_exec(s_)
  #local fn_ = "/tmp/parse_fore.tmp";
  #fopen fp_ fn_ write
  #write (fp_, s_)
  #fclose fp_
  #debug "fore_exec(s_).... \n" // BW
  #debug concat (s_, "\n")
  #include fn_
#macro fore_call(a_,s_,f_)
  #if (f_)
    #local rtn_ = fore_exec(s_);
  #else
   #debug "fore_call 1.... \n" // BW
    fore_exec(s_)
    #local rtn_ = 1;
  #if (fore_debug)
    #debug concat("call '",s_,"' returned '",str(rtn_,0,0),"'.\n")
  #debug "fore_call 2.... \n" // BW
  rtn_
and
#macro mkSphere (p_, d_, c_)
 #debug "executing mkSphere... \n"
 0)
  sphere {
    p_, d_
    pigment {colours_[c_]}
Date: 3 Apr 2021 17:15:00
Message: <web.6068da4954e5aaba79819d986cde94f1@news.povray.org>
hi,
hmm, the 'bigSphere' macro does work until one tries to instantiate an object,
it runs otherwise.  and, well, I cannot see anything amiss.
yes, as it should, having just a '0)' before the primitive.  I don't get the
line before thing but suspect it's for the same reason -- extra ("spurious")
characters.
as for adding more output in the include, the error does occur in the scene
file.  (btw, a 'bool' type payload with debug on will print return info).
thanks for looking.
regards, jr.
Date: 3 Apr 2021 17:55:00
Message: <web.6068e3e554e5aaba1f9dae3025979125@news.povray.org>
> characters.
Right on, but we're looking at "as it shouldn't".
I commented out the macro call in bigSphere  (look at you, using capital
letters... :o)  and put an actual sphere in its place.
Same error.
Put a 1 on the line above it.   Same error as last time.
But when I closed the ), this time I got
at File: fore_demo.pov Line: 213 Col: 1
So the error gets triggered in the scene file, but seems to be actually due to
an omission in some nested thing in the include file.
Also, 213 is a different line than when I did the 0) in the mkSphere macro.
If you can't find the issue, you may have to resort to mapping the nesting
levels like I did in that blood cells scene.
Date: 3 Apr 2021 18:05:00
Message: <web.6068e5ad54e5aaba1f9dae3025979125@news.povray.org>
Further,
if I put a 2) before the #debug statement in bigSphere, it complains about line
_214_ instead.
You've got an extra ( somewhere that got injected or a missing ), or something
even harder to track down.
Just on the off chance:
The file is clean and has none of those weird non-ASCII characters, ...?
Date: 3 Apr 2021 18:20:00
Message: <web.6068e8ec54e5aaba79819d986cde94f1@news.povray.org>
hi,
> Same error.
yes, I too tried that.
maybe I should have mentioned earlier.  before I got to the stage of calling
payload macros, I worked to get the "walking" done properly.  for that I've a
test scene with arrays from one to five dims, and the 'fore_call()' at the time
only spat out the 'cmd_' content, ie the index/indices of the current element.
while it is possible that I fucked up, I did test pretty thoroughly.
my gut feeling, given the "because it is looking for a numeric expression", is
that the parser somehow expects a RHS where it sees an object/primitive.
(and to add to the indignation :-), earlier I'd written a camera {} and left
forgot to fill in the details, and .. not a beep from the program.)
yes, last resort though.  I do hope "one of the gods" can shed some light on
this.
regards, jr.
Date: 3 Apr 2021 18:45:00
Message: <web.6068ef0754e5aaba1f9dae3025979125@news.povray.org>
To CYA, check your "end"s    :D
I noticed that you have a
#ifndef (fore_include_temp)
but I'm not sure where it should be terminated.
Also, I'm not sure if there are enough #ends in
#macro Foreach(arr_,mac_,flg_,optional dim_)
I would sorely love different terminators for #macro, #if, #for, #while, etc....
Date: 3 Apr 2021 19:15:00
Message: <web.6068f67e54e5aaba79819d986cde94f1@news.povray.org>
hi,
are you looking at an unmodified file?  if yes, as posted, the indentation looks
correct.
line 429.  :-)
no spare or missing '#end's, I'm confident.
(do you need to top up caffeine level?  :-))
(and please give it a whirr with some "normal" macros.  any errors?)
yes, self prefers braced blocks (think Tcl), eg '#for () { ... }'.
regards, jr.
Date: 3 Apr 2021 19:55:00
Message: <web.6069002f54e5aaba1f9dae3025979125@news.povray.org>
Yes.
Though with what you've got going on, I'm gonna need either some crystal meth -
or a crystal ball - to see how you've gone and broken things this time.   :P
I think that with this, you are trying to get into the running on "Who breaks
POV-Ray the most?"
Give WHAT a whirr...
Well, yes, that would be functional.
But I would still prefer #endif #endfor #endwhile #endmacro
as it would allow some interesting coding that wouldn't otherwise be possible
with equally ambiguous {'s
Date: 3 Apr 2021 20:20:00
Message: <web.6069059554e5aaba79819d986cde94f1@news.povray.org>
hi,
> Yes.
</grin>  thanks.  can do with some lightheartedness.  :-)
the 'Foreach()'.  I'm sure you've plenty data (lingering in arrays).  if the
payload macros just do calculations etc, I'd expect it to run w/out issues.
intrigued.  what can you not do with just '#end's?
regards, jr.
