POV-Ray : Newsgroups : povray.bugreports : alpha.10064268 undef behaviour Server Time
15 Dec 2025 22:18:46 EST (-0500)
  alpha.10064268 undef behaviour (Message 1 to 6 of 6)
Subject: alpha.10064268 undef behaviour
Date: 13 Aug 2020 06:50:01
Message: <web.5f351a7de6b33f6a4d00143e0@news.povray.org>
hi,
I was looking over my 'queues.inc' code[*], and got errors when running the
test/demo scenes.  all three test scenes work ok when using the alpha.9945627,
but with the alpha.10064268, which I installed a few days after posting :-), I
get:
Persistence of Vision(tm) Ray Tracer Version 3.8.0-alpha.10064268.unofficial
==== [Parsing...] ==========================================================
found 33 in B in first 500.
File '/usr/local/share/povray-3.8/extra/queues.inc' line 59: Possible Parse
 Error: Uncategorized error thrown at parser/symboltable.cpp line 440.
Fatal error in parser: Uncategorized error.
Render failed
File '/usr/local/share/povray-3.8/extra/queues.inc' line 118: Possible Parse
Render failed
the quick brown fox jumped
total 5 elements queued.
quick, the brown fox jumped
File 'tstqp.pov' line 176: Parse Warning: No objects in scene.
lines 59 and 118 contain an '#undef', as does line 225.  yet, two tests fail,
one succeeds, and I cannot see a difference.
[*] <http://news.povray.org/web.5dddb9c6ed272ff4feeb22ff0%40news.povray.org>
regards, jr.
Subject: Re: alpha.10064268 undef behaviour
Date: 13 Aug 2020 09:23:05
Message: <5f353eb9$1@news.povray.org>
On 8/13/20 6:48 AM, jr wrote:
> hi,
> get:
The two which fail are using float id tokens where the first does not.
In symboltable.cpp Christoph added:
// TODO See captured issue:
// jr_Parse_alpha_10064268_to_10064268_Aug13_2020
//         POV_EXPERIMENTAL_ASSERT((ttype != FLOAT_TOKEN_CATEGORY) &&
//                                 (ttype != FLOAT_ID_TOKEN) &&
//                                 (ttype != VECTOR_TOKEN_CATEGORY) &&
//                                 (ttype != COLOUR_TOKEN_CATEGORY));
// I "think" Christoph wanted something like that below.
// BUT! Why didn't he just differently order FLOAT_ID_TOKEN,
// VECTOR_ID_TOKEN as he looks to have ordered COLOUR_ID_TOKEN
// This looks like something not complete and certainly not clean.
         POV_EXPERIMENTAL_ASSERT(((ttype != FLOAT_TOKEN_CATEGORY) ||
                                  (ttype == FLOAT_ID_TOKEN)) &&
                                 ((ttype != VECTOR_TOKEN_CATEGORY) ||
                                  (ttype == VECTOR_ID_TOKEN)) &&
I'm going to run with the change at the bottom for a while in povr and
see what happens. Your test cases again run with the change.
I think though this a v38 release issue where somebody needs to spend a
chunk of time 'really' getting to understand the state of the current
parser code to determine the 'right' solution. I'm guessing a little
given the code state - and that state doesn't looks clean to me.
Bill P.
Date: 13 Aug 2020 10:20:00
Message: <web.5f354b95f20bf6fd4d00143e0@news.povray.org>
hi,
> > I was looking over my 'queues.inc' code[*], and got errors ...
thank you for looking into it.  did a quick test loading a few strings via
'qqPut()' and yes, that works as should.  (strange that the content of an array
element should matter)
yeah, forgot to mention, 'povr' was same as alpha.10064268.
if, after some time, the change you made to 'symboltable.cpp' looks to be
trouble-free, could you post a diff for users (me :-)) to try, please?
regards, jr.
Date: 13 Aug 2020 12:27:03
Message: <5f3569d7$1@news.povray.org>
If something changes in approach for povr, I'll try to remember.
For the near future, the diff - aside from comments I added here and
there in the povr code base should I eventually dig deeper - is simply
replacing the current POV_EXPERIMENTAL_ASSERT() with the modified one in
my post.
Bill P.
Date: 13 Aug 2020 13:45:00
Message: <web.5f357bacf20bf6fd4d00143e0@news.povray.org>
hi,
> my post.
ok, good info.  cheers.
regards, jr.
Date: 29 May 2021 14:04:34
Message: <60b28232$1@news.povray.org>
Am 13.08.2020 um 15:23 schrieb William F Pokorny:
> //                                 (ttype !=
FLOAT_ID_TOKEN) &&
> //                                 (ttype !=
> //                                 (ttype !=
Yeh, that's the offending statement; but...
>                                   (ttype ==
FLOAT_ID_TOKEN)) &&
>                                  ((ttype !=
>                                   (ttype ==
>                                  (ttype !=
... that doesn't make any sense whatsoever, because `(ttype ==
FLOAT_ID_TOKEN)` can only hold true if `(ttype != FLOAT_TOKEN_CATEGORY)`
is true anyway.
Nay, the answer is a different one. `(ttype != FLOAT_ID_TOKEN)`
shouldn't have made it in there in the first place. Also, there's one
*_CATEGORY value missing from the list, namely
`SIGNATURE_TOKEN_CATEGORY`. Which for reasons of neatness should be the
first in the list.
I'll commit a fix to the repo soon.
