POV-Ray : Newsgroups : povray.bugreports : local in macro Server Time
15 Dec 2025 22:18:19 EST (-0500)
  local in macro (Message 1 to 3 of 3)
Subject: local in macro
Date: 28 Nov 2019 07:25:01
Message: <web.5ddfbbcda28041b5feeb22ff0@news.povray.org>
hi,
upgraded from alpha.9945627 because I ran into a problem, to alpha.10064268, but
no change.
reading section 3.3.2.2.2 "declare vs local", it says if "#local is used inside
a #macro then the identifier is local to that macro.  When the macro is invoked
and the #local directive is parsed, the identifier is created."
maybe I misread this, but the macro parameter appears to just work as an
input/output.  the following test scene .. misbehaves on both versions:
-----<snip>-----
#version 3.8;
global_settings {assumed_gamma 1}
#macro Decr(n_)
  #if (1 <= n_)
    #local n_ = n_ - 1;
  #debug concat("local n_ = ",str(n_,0,0),"\n")
#if (1)
#for (i_,0,3)
  Decr(i_)
  #debug concat("loop i_ = ",str(i_,0,0),"\n")
#if (0)
#declare i_ = 0;
#while (4 > i_)
  Decr(i_)
  #declare i_ = i_ + 1;
-----<snip>-----
regards, jr.
Subject: Re: local in macro
Date: 28 Nov 2019 10:25:01
Message: <web.5ddfe6578fffca174eec112d0@news.povray.org>
> #version 3.8;
> #macro Decr(n_)
>   #if (1 <= n_)
>     #local n_ = n_ - 1;
>   #end
> #end
> #if (1)
> #for (i_,0,3)
>   Decr(i_)
> #end
> #end
> #if (0)
> #declare i_ = 0;
> #while (4 > i_)
>   Decr(i_)
> #end
> #end
Not sure exactly what you're trying to do here, but try this and see if this
helps explain anything.   I think Kenneth had some issues with this sort of
thing too a while back.
#version 3.8;
#declare Bailout = 0;
#declare Bailoutmax = 10;
#macro Decr (n_)
 #debug concat("starting macro with n_ = ",str(n_,0,0),"\n")
 #if (n_ >= 1)
  #local n_ = n_ - 1;
 #if (Bailout = Bailoutmax)
  #error "Stopping code - Bailout has reached max"
 #debug concat("     exiting macro with n_ = ",str(n_,0,0),"\n")
 n_
#if (1)
 #declare Counter = 10;
 #for (i_, 0, 3)
  #declare Counter = Decr (Counter);
  #declare Bailout = Bailout + 1;
#if (0)
 #declare i_ = 0;
 #while (i_ < 4)
  #declare i_ = Decr (i_);
  #debug concat("while loop i_ = ",str(i_,0,0),"\n")
#error "stop render"
Date: 28 Nov 2019 14:15:01
Message: <web.5de01c568fffca17feeb22ff0@news.povray.org>
hi,
my work-around for the issue will be (from now) to treat macro parameters as
read only.  confused by the documentation, I guess.  reading through the
language directives stuff (local vs declare, macros) I expect the local variable
('n_') to genuinely be local since the reassignment is a '#local' construct, but
it seems that it remains linked "by reference" regardless.  anyway, thanks for
the thought.
regards, jr.
