POV-Ray : Newsgroups : povray.bugreports : file directory problem Server Time
7 Sep 2025 18:01:48 EDT (-0400)
  file directory problem (Message 1 to 8 of 8)
Subject: file directory problem
Date: 7 Apr 2019 19:05:00
Message: <web.5caa81f5bd119c2a968d6dc0@news.povray.org>
hi,
getting an error I cannot understand.
Script started on Sun 07 Apr 2019 23:52:16 BST
jr@crow:1:sinkflip$ pov38 sf2b1
Persistence of Vision(tm) Ray Tracer Version 3.8.0-alpha.10013324.unofficial
Rendering frame 1 of 72 (#0)
Stream output files must reside in same directory as image output file.
Render failed
the .ini file contains (edited):
all_file = /tmp/render/sf/LOG
initial_frame = 0
final_frame = 71
input_file_name = sf2b1.pov
output_file_name = /tmp/render/sf/frame_
regards, jr.
Subject: Re: file directory problem
Date: 8 Apr 2019 11:48:48
Message: <5cab6d60$1@news.povray.org>
Le 08/04/2019 à 01:04, jr a écrit :
> hi,
> Render failed
Basic problem due to IO restrictions being active (default).
Well, not a real problem, works as intended, to protect the innocents.
see
http://wiki.povray.org/content/Documentation:Unix_Section_4#I.2FO_Restrictions
So, as the message can be read: your log file must be in the same
directory as the image output file.
you need to tune the configuration of the io-restrictions to be more
relaxed.
I live in a dangerous world, my default compilation option is
--disable-io-restrictions, but that's me, and it might not be good for all.
> initial_frame = 0
> final_frame = 71
> regards, jr.
Date: 8 Apr 2019 12:15:00
Message: <web.5cab733e1c4d9672968d6dc0@news.povray.org>
hi,
fingers crossed.  :-)
> see ...
> relaxed.
so this is the private 'povray.conf':
; POV-Ray 3.8
[File I/O Security]
restricted
[Shellout Security]
allowed
[Permitted Paths]
read* = /usr/share/fonts/local
read* = %INSTALLDIR%/include
read* = %INSTALLDIR%/scenes
read* = %INSTALLDIR%/extra
read+write* = /tmp
read+write* = %HOME%
and /tmp and its descendants work.  usually.  what needs to be relaxed?
regards, jr.
Date: 9 Apr 2019 09:05:00
Message: <web.5cac97991c4d9672968d6dc0@news.povray.org>
hi,
> > Render failed
for laughs I changed 'File I/O Security' to 'none' in both the site-wide and the
personal configuration files.  no dice.  same error, even though both stream +
image output files would "reside in same directory".
regards, jr.
Date: 9 Apr 2019 13:26:52
Message: <5cacd5dc$1@news.povray.org>
Le 09/04/2019 à 15:02, jr a écrit :
> hi,
>>> Render failed
which paths ?
/usr/local/etc/povray/3.8 or
/usr/local/etc/povray/3.7 ?
Can you recompile with --enable-debug, and have a look at the start of
the output when you launch povray ?
I have that:
PATHS
  HOME        = /home/jerome
  SYSCONF     = /usr/local/etc/povray/3.8/povray.conf
  USERCONF    = /home/jerome/.povray/3.8/povray.conf
  SYSINI      = /usr/local/etc/povray/3.8/povray.ini
  SYSINI_OLD  = /usr/local/etc/povray.ini
  USERINI     = /home/jerome/.povray/3.8/povray.ini
  USERINI_OLD = /home/jerome/.povrayrc
PARSE CONF '/usr/local/etc/povray/3.8/povray.conf'
  CANONICALIZE '%INSTALLDIR%/include/'
    su: /usr/local/share/povray-3.8/include/
PERMITTED ADD '/usr/local/share/povray-3.8/include/'
  CANONICALIZE '%INSTALLDIR%/scenes/'
    su: /usr/local/share/povray-3.8/scenes/
PERMITTED ADD '/usr/local/share/povray-3.8/scenes/'
  CANONICALIZE '%INSTALLDIR%/../../etc/'
    su: /usr/local/share/povray-3.8/../../etc/
    su: /usr/local/share/../etc/
PERMITTED ADD '/usr/local/share/../etc/'
  CANONICALIZE '%HOME%/'
    su: %HOME%/
    su: /home/jerome/
    su: /home/jerome/
    su: /home/jerome/
PERMITTED ADD '/home/jerome/'
  CANONICALIZE '/tmp/'
    su: /tmp/
    su: /tmp/
    su: /tmp/
    su: /tmp/
PERMITTED ADD '/tmp/'
  CANONICALIZE './'
    su: ./
    su: ./
    su: ./
    su: ./
PERMITTED ADD '/usr/local/etc/povray/3.8/'
I/O RESTRICTIONS
  file_io  = 0	config->file_io  = 0
  shellout = 1	config->shellout = 1
PARSE CONF '/home/jerome/.povray/3.8/povray.conf'
    su: %HOME%/
    su: /home/jerome/
    su: /home/jerome/
    su: /home/jerome/
    su: /tmp/
    su: /tmp/
    su: /tmp/
    su: /tmp/
  CANONICALIZE './'
    su: ./
    su: ./
    su: ./
    su: ./
I/O RESTRICTIONS
  shellout = 2	config->shellout = 2
PERMITTED PATHS
  READ* = "/usr/local/share/povray-3.8/include/"
  READ* = "/usr/local/share/povray-3.8/scenes/"
  READ* = "/usr/local/share/../etc/"
  READ* = "/home/jerome/"
  WRITE* = "/tmp/"
  WRITE = "/home/jerome/"
OPTIONS (6)
  version = off(--version|-version|--V, )
  temppath = (, POV_TEMP_DIR)
  help = off(--help|-help|-h|-?, )
  generation = off(--generation, )
  benchmark = off(--benchmark|-benchmark, )
  scaled = on(, POV_DISPLAY_SCALED)
> regards, jr.
Date: 9 Apr 2019 14:25:05
Message: <web.5cace3351c4d9672968d6dc0@news.povray.org>
hi,
> which paths ?
only 3.8 versions installed on this machine.
ok.  will do, next couple of days or so.  thanks.
regards, jr.
Date: 9 Apr 2019 17:30:12
Message: <5cad0ee4$1@news.povray.org>
Am 08.04.2019 um 01:04 schrieb jr:
Is there perhaps a directory named `LOG`?
Also, what happens if you just specify `all_file=LOG`?
Or is `frame_` perhaps a directory?
Date: 9 Apr 2019 18:20:00
Message: <web.5cad1a5d1c4d9672968d6dc0@news.povray.org>
hi,
bingo.  'LOG' is created in same directory as frame_* files.  automatically.
nice.
thank you.
regards, jr.
