POV-Ray : Newsgroups : povray.bugreports : Error with big *.inc file Server Time
21 Mar 2026 10:16:14 EDT (-0400)
  Error with big *.inc file (Message 1 to 10 of 11)
Subject: Error with big *.inc file
Date: 29 Aug 2014 04:35:00
Message: <web.54003aaef370693040e8111a0@news.povray.org>
I get the following error when using a big inc file:
"C:\Temp\POV\Mesh_tracts_big.inc" line 64136462: Parse Error: No matching } in
'object', float function 'float constant' found instead.
But there is nothing wrong with that file. Note that I do *not* get any error
when I use smaller file.
I have put the relevant files (Mesh_tracts_big.inc, Mesh_tracts_small.inc and
Scene_def.pov) here (~1/2 GB zip file):
http://www.isi.uu.nl/People/Alexander/files/POV.zip
I am using Windows 7 Professional 64 bit OS (24 threads with 128 GB RAM). To
render the big file, you need ~30 GB RAM. I used both the latest POV-Ray version
and the previous one... no luck!
Many thanks in advance for any help!
Cheers,
Alexander
Subject: Re: Error with big *.inc file
Date: 29 Aug 2014 06:58:05
Message: <54005cbd$1@news.povray.org>
> Cheers,
> Alexander
Hmmm ... OK I'm seeing something similar with a big include file (> 75M)
that I've been using for ages and /haven't/ touched since 2011
ash@linux-c2bm:~/POV-Ray/Source $ ll ../Includes/gargoyle.inc
-rw-r--r-- 1 ash users 75777971 Apr  6  2011 ../Includes/gargoyle.inc
File '/users/ash/POV-Ray/Includes/gargoyle.inc' line 2868724: Parse
Error: Illegal character in input file, value is b7.
Fatal error in parser: Cannot parse input.
Odd that things worked fine two days ago (and yesterday) ... Indeed when
I bring the file into gedit it halts reading the file for "illegal
character" so I canceled ... however reading the file with vi I see a
problem at the offending line:
I've seen this before (different include), but didn't follow up as I was
sure it would be one of those "I can't duplicate it" cases and I dropped
it ... now with another user having problems I feel it's prudent to
speak up now.
Date: 29 Aug 2014 07:06:21
Message: <54005ead$1@news.povray.org>
>> matching } in
>> any error
>> RAM). To
>> POV-Ray version
>> Cheers,
>> Alexander
> speak up now.
commented out offending line and now I get:
File '/users/ash/POV-Ray/Includes/gargoyle.inc' line 3097900: Parse
Error: Expected 'numeric expression', } found instead
... it parsed past previous error and made it to the end of the file
Date: 29 Aug 2014 11:55:00
Message: <web.5400a1649ede3cc7a3e03fe0@news.povray.org>
> Cheers,
> Alexander
I am using Linux Mageia-4 64 bit OS (i3 with 16 GB RAM).
No problem with Mesh_tracts_big.inc (3.1 GB)
Look here:
http://news.povray.org/povray.binaries.images/attachment/%3Cweb.5400a08ac27938b17a3e03fe0%40news.povray.org%3E/big_inc.
jpg
Date: 29 Aug 2014 13:25:00
Message: <web.5400b7329ede3cc40e8111a0@news.povray.org>
> > Cheers,
> > Alexander
> Look here:
c.
> jpg
Great - so this confirms that there is nothing wrong with the files ;-)! Unless
someone can get it working on a Windows OS, this remains a bug, not?!
Any suggestions on how to fix it - besides getting a Linux OS ;-)?
Kind regards,
Alexander
Date: 29 Aug 2014 14:17:05
Message: <5400c3a1$1@news.povray.org>
>>> Cheers,
>>> Alexander
>> Look here:
> c.
>> jpg
> Kind regards,
> Alexander
don't think it's exclusive to windows ... i'm linux user. didn't test
your specific case but i've seen this problem in the past, and
coincidentally just the other day with a large include that i've used in
the past (just two days ago) without difficulty. /nothing/ on my system
has changed. as a matter of fact had it happen /before/ 3.7 release but
kept my mouth shut ... well because and i won't get into that
Date: 29 Aug 2014 14:25:00
Message: <web.5400c4f89ede3cc7a3e03fe0@news.povray.org>
It would be desirable to learn as well as where such model is created?
Date: 29 Aug 2014 16:00:01
Message: <web.5400da609ede3cc40e8111a0@news.povray.org>
First some good news: I've found a way around the problem... splitting up all
the data from the big *.inc file and then simply writing multiple smaller *.inc
files does the job ;-)!
Second, to answer your question, I've created this model of brain fiber
trajectories based on diffusion MRI data. Want to know more? See
http://providi-lab.org
Cheers,
-A
PS: while I'm at it... does anybody know how to make a mesh2 object look like
it's emitting light?
Date: 29 Aug 2014 16:20:04
Message: <web.5400df439ede3cc7a3e03fe0@news.povray.org>
How it can be done with one object?
I created from the Mesh_tracts_big.inc the OBJ file - 1.1 GB.
The Blender falls when importing
Thanks!
Date: 29 Aug 2014 16:50:01
Message: <web.5400e66f9ede3cc40e8111a0@news.povray.org>
> Thanks!
Now, I actually use multiple objects. For example:
object{
#include "F:\Data\POV_RAY\Mesh_tracts_1.inc"
object{
#include "F:\Data\POV_RAY\Mesh_tracts_2.inc"
object{
#include "F:\Data\POV_RAY\Mesh_tracts_3.inc"
object{
#include "F:\Data\POV_RAY\Mesh_tracts_4.inc"
object{
#include "F:\Data\POV_RAY\Mesh_tracts_5.inc"
Cheers,
-A
