POV-Ray : Newsgroups : povray.bugreports : Animations. malloc(): unsorted double linked list corrupted Server Time
17 Nov 2025 00:05:39 EST (-0500)
  Animations. malloc(): unsorted double linked list corrupted (Message 1 to 5 of 5)
Subject: Animations. malloc(): unsorted double linked list corrupted
Date: 6 Apr 2025 03:09:38
Message: <67f228b2$1@news.povray.org>
Posting as a hook so others who might see this failure can find it and
provide information.
If you have seen this issues or have just hit it, please post here -
along with environment, running conditions, frequency, etc.
In the last six months or so I've been using the animation facilities in
POV-Ray (yuqk) more than ever. Sometimes to create actual animations,
but more often as a way to explore feature options. Or, as with the
text{} object recently, to run down some crash already, infrequently,
seen in non-animation (single frame/image) renders.
Today, for the second time in the last month, I had a long running
animation core dump with a "malloc(): unsorted double linked list
corrupted" error(*). Both times the animation frames, rendering was
working in the background while I was doing other interactive work. Both
times the animation completed without issue once resumed.
I'm kicking off some intentionally long running (many frame) dummy
animations trying to trip this error while running my debug compile. I'm
hoping to capture an annotated core dump file. Maybe I'll get lucky, but
I doubt it. I guess something like valgrind an option - if I find myself
really motivated.
Linux. x86-64. My yuqk, v3.8 based fork releases R19 and working state,
R20 code. Both times the scenes were small - with memory requirements
<100MB.
lsb_release -a :
     No LSB modules are available.
     Distributor ID: Ubuntu
     Description:    Ubuntu 24.04.2 LTS
     Release:        24.04
     Codename:       noble
g++ --version : g++ (Ubuntu 13.3.0-6ubuntu2~24.04) 13.3.0
ldd --version : ldd (Ubuntu GLIBC 2.39-0ubuntu8.4) 2.39
uname -r      : 6.8.0-57-generic
Bill P.
(*) - The error message comes from glibc prior to things crashing.
Subject: Re: Animations. malloc(): unsorted double linked list corrupted
Date: 6 Apr 2025 08:44:23
Message: <67f27727$1@news.povray.org>
If it is indeed a bug, you should be able to reproduce it if you enable
memory debugging by defining the various macros in pov_mem.cpp (in
particular MEM_GUARD) when compiling POV-Ray.
The other, and more likely, option - if this only occurs during long
renders - may very well be memory corruption due to overheating
problems. Nowadays this also tends to be a problem for memory due to
overall heat being generated.
Thorsten
> really motivated.
> <100MB.
> lsb_release -a :
>      Release:        24.04
>      Codename:       noble
> Bill P.
Date: 7 Apr 2025 08:15:44
Message: <67f3c1f0$1@news.povray.org>
Thank you for the information. I'd not considered overheating as a
potential cause.
I spent some time earlier this morning looking at the C style memory
handling I could find in the source code - as well as what in particular
was using code from pov_mem.cpp.
Other than functions, which were common to both animations which
crashed, I wasn't using much beyond the povms code(*). There are still
too some allocations and frees to set up for possible blobs around the
rendering of each frame, for example.
My dummy long animation renders have all finished clean. I'll try to get
a MEM_GUARD build going today and run more of those.
Bill P.
(*) - I found that the messaging code doesn't use the pov_mem versions,
but rather raw C malloc(), realloc() and free().
Date: 7 Apr 2025 15:25:12
Message: <67f42698$1@news.povray.org>
On 4/7/25 08:15, William F Pokorny wrote:
> I'll try to get a MEM_GUARD build going today and run more of those.
Update.
A build with MEM_GUARD and MEM_TAG defined just finished a second long
set of animation frames. No warnings or errors. I tried a handful of
still frame scenes and they too ran clean.
I'll run a few more animation sequences overnight and then, unless
something goes boom, I'll likely pause the chase. It's not failing often
enough at present for me to give it a high priority.
Bill P.
Date: 8 Apr 2025 08:30:09
Message: <67f516d1$1@news.povray.org>
Yes, it needs memory allocation outside the main code because it must be
able to handle low and out of memory conditions.
On Linux it may also be that the C++ library calls malloc for handling
new. There used to be overrides for new/delete somewhere that could use
the POV-Ray internal memory allocation functions, but they may since
have been removed. If so, you can always use Memcheck from Valgrind.
Thorsten
