POV-Ray : Newsgroups : povray.bugreports : povray.conf contains evil directory Server Time
15 Dec 2025 22:17:06 EST (-0500)
  povray.conf contains evil directory (Message 1 to 8 of 8)
Subject: povray.conf contains evil directory
Date: 10 Oct 2019 02:30:26
Message: <5d9ed002$1@news.povray.org>
Line 94 of the default unix povray.conf contains a reference to
%INSTALL_DIR%/../../etc
https://github.com/POV-Ray/povray/blob/master/unix/povray.conf
This is the exact unix directory we *don't* want povray to read.
This line should be removed.
dik
Rendered 1024 of 2073600 pixels (0%)
Subject: Re: povray.conf contains evil directory
Date: 11 Oct 2019 04:13:33
Message: <5da039ad$1@news.povray.org>
On my Ubuntu system this resolves to /usr/local/etc for an actual system
install - which is OK I think. It's where the system wide povray.conf
and povray.ini files are installed and these I believe set the file i/o
access rights all users picking up the common install would get.
Am I missing something?
On your system are you ending up with /etc readable due a different tool
install directory structure, or?
Bill P.
Date: 11 Oct 2019 06:29:38
Message: <5da05992$1@news.povray.org>
> Bill P.
For me, on debian/ubuntu/mint, povray/qtpovray ends up at
/usr/share/povray-3.7
/usr/share/qtpovray-3.8
so the evil dir is
/usr/etc
which does not exist.
Technically, the evil dir is undefined.
I still submit that there is no legitimate reason to ever access
%INSTALL_DIR%/../anything
especially etc, which just makes it an incompetent evil.
dik
Rendered 95232 of 2073600 pixels (22%)
Date: 11 Oct 2019 07:25:00
Message: <web.5da065e9783a8ea6feeb22ff0@news.povray.org>
hi,
weird.  neither is "system" software, so should go under '/usr/local' (or
'/opt'), aiui.
regards, jr.
Date: 11 Oct 2019 08:49:18
Message: <5da07a4e$1@news.povray.org>
On 10/11/19 7:22 AM, jr wrote:
> hi,
> '/opt'), aiui.
> regards, jr.
/usr/share: Architecture-independent (shared) data.
https://en.wikipedia.org/wiki/Filesystem_Hierarchy_Standard
I have 351 directories of foo under /usr/share
/usr/local is for stuff I build myself.  I didn't, I installed the
"official" debian package.
/opt is for optional.   Good for whole self contained self-downloaded
packages.  Like /opt/eclipse and /opt/Qt.
I'm curious, on your slackware system, where do your *.vim files live?
(like filetype.vim)  The povray %INSTALLDIR% is a cousin of that.
dik
Date: 11 Oct 2019 09:30:00
Message: <web.5da082cf783a8ea6feeb22ff0@news.povray.org>
hi,
> > '/opt'), aiui.
thanks.  could have sworn there's a section 7 man page too, but cannot find it
now.  :-(
still, strange choice.  conflict between build system and packaging tool?  in my
(nvh) opinion, the packages should install under '/usr/local', and the
"architecture independent" stuff under '/usr/local/share'.
wrt '/opt', _if_ POV-Ray installed as '/opt/povray/{bin,etc,share}', I'd be ok
with that too.
if you create your own (qtpovray) package, does that differ from the official
package?  (blame the maintainer!  ;-))
'/usr/share/vim'.  however, the editor is (of course) part of the system s/ware.
regards, jr.
Date: 11 Oct 2019 11:17:34
Message: <5da09d0e$1@news.povray.org>
On 10/11/19 9:25 AM, jr wrote:
> hi,
>>> '/opt'), aiui.
> now.  :-(
> with that too.
> regards, jr.
With respect to /opt/<package>, on my Ubuntu system at the moment I have
the /opt mount point, but nothing there. When you install something like
/opt/eclipse, does that install update PATH and so on for everyone on
the system?
The user PATH is set up already with /usr/bin and /usr/local/bin so an
executable placed in either of those directories naturally gets picked up.
With respect to the povray etc directory, I think builds are hard coded
to look for it and those two files, but uncertain of details. If
correct, it means any change will be more than just deleting that
povray.conf line. We'd need to find another home for those /etc files.
I'm not very familiar with the package build process, but for my
/usr/local installs the necessary /etc directory was created - povray
stuff 3.7 and 3.8 versions is all that's there. Does this sort of
directory creation not happen on /usr/share distribution package installs?
Is perhaps <>/etc out of favor as a directory these days?
Bill P.
Date: 11 Oct 2019 11:45:01
Message: <web.5da0a34b783a8ea6feeb22ff0@news.povray.org>
hi,
> >>> '/opt'), aiui.
> > now.  :-(
> > with that too.
> > regards, jr.
> the system?
can only answer one of the questions.  typically a package installing in '/opt'
provides a 'somepackage.{sh,csh}' to go into '/etc/profile.d' where the shell
picks it up on login; Qt5 is an example, all it does is set an environment
variable and append the PATH.
like you, I never had "trouble" with POV-Ray installing under '/usr/local', it
just works.  why would/should the 'povray.{conf,ini} not go under
/usr/local/etc'?
regards, jr.
