POV-Ray : Newsgroups : povray.bugreports : rendering lathe objects generates faulty surfaces at the origin Server Time
6 Feb 2026 03:08:48 EST (-0500)
  rendering lathe objects generates faulty surfaces at the origin (Message 1 to 3 of 3)
Subject: rendering lathe objects generates faulty surfaces at the origin
Date: 23 Jun 1999 19:22:19
Message: <37716CC4.D02EBE2D@t-online.de>
The following code should produce something looking like a "vulcano
crater"
using a lathe object.
However, the center portion around the symmetry point (center of the
vulcano)
does not render properly.
This looks a bit like the bug concerning a too large value of EPSILON
which is
reported in this newsgroup.
I did, however, find any reference to EPSILON in config.ini. How can I
change it and
does it really solve the problem ?
// lathe rendering does not render properly in the vicinity of <0,0,0>
// Win95 4.00.950B PII 300
// Povray 3.1e.msvc.win32 (PII optimized)
// File by Stefan Hahn ste### [at] t-onlinede
global_settings { assumed_gamma 2.2 }
#declare eye = <-0.3,0.5,-0.3>
   lathe {
      linear_spline 4
      <0.000,0>
      <0.01,0.004>
      <0.02,0.0>
      <0.000,0>
      interior {ior 1.2} pigment {colour rgb<1,1,1>} finish{ambient 0.2
diffuse 0.8}
   angle 1
   location eye
   up <0, 0.5, 0> right <0.6666, 0, 0>
   look_at <0,0,0>
light_source { <10, 100, -100> colour rgb<1,1,1> }
Subject: Re: rendering lathe objects generates faulty surfaces at the origin
Date: 24 Jun 1999 10:04:01
Message: <37723ad1@news.povray.org>
Stefan Hahn <Ste### [at] t-onlinede> wrote:
: However, the center portion around the symmetry point (center of the
: vulcano) does not render properly.
  Seems like a precision problem. Scaling everything by about 10 solves
the problem.
  This is the core of the problem:
#declare Scale = 1;
#declare eye = <-0.3,0.5,-0.3>*Scale;
lathe
{ linear_spline 2
  <0,0> <.01,.004>*Scale
  pigment { rgb 1 }
camera { angle 1 location eye look_at 0 }
light_source { y*10,1 }
  If you set Scale to 10, everything seems to be ok.
Date: 24 Jun 1999 15:01:12
Message: <377280D2.290A3B02@t-online.de>
Dear Nieminen,
Thanks a lot for the fix. Since this problem was only part of a larger
model, in which I dimensioned all using physical parameters [meters]
your fix looked a bit inconvenient.
However, a slight modification of your code seems to be the
perfect fix:
modeling the lathe at a dimension 10 like you proposed, but scaling the whole
object
down it by a factor of 10 immediately afterwards worked out equally well.
Thanks again.
Unfortunately after this fix, I just fell into the next hole concerning
CSG intersections of a transparent lathe's. I am hoping to be helped
out of this hole as well. (see subsequent posting)
***sth***
> the problem.
> #declare Scale = 1;
> lathe
> { linear_spline 2
>   pigment { rgb 1 }
