POV-Ray : Newsgroups : povray.bugreports : String literals can only be 125 characters long Server Time
16 Dec 2025 06:39:22 EST (-0500)
  String literals can only be 125 characters long (Message 1 to 10 of 16)
Subject: String literals can only be 125 characters long
Date: 2 Jun 1999 20:57:38
Message: <3755c4f2.0@news.povray.org>
Found another minor one, string literals don't seem to behave as the
documentation says:
   String literals begin with a double quote mark '"' which is followed by
up to 256 printable ASCII characters and are terminated by another double
quote mark.
This string literal contains 126 X's and fails while parsing with a string
too long error:
#declare
Test="XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX"
By the way, the documentation doesn't state how long strings can become, you
can concat strings to over 256 characters, I tried to over 2,000,000 which
seems to work fine. Which also provides the workaround for the bug above.
Still using NT4 with the standard binaries.
Samuel
Subject: Re: String literals can only be 125 characters long
Date: 3 Jun 1999 04:16:24
Message: <37562bc8.0@news.povray.org>
I still wonder why all these limitations in povray. String literals
limited to 256 characters (or 125 or whatever), nested #includes
limited to about 10, recursive #macros limited to something, number
of parameters to a #macro limited to some number...
  Why?
  It should be very easy to parse a string literal without length limitations
(compilers do). Just count the number of characters, allocate that amount
of memory and copy it there.
  Unlimited #macro recursion and nested #includes should also be possible
(although for some strange reason most compilers have also a nested
#include limit; but afaik there's no limit for recursive macros). Just
make a stack data structure.
  The parameters to a #macro could be a list.
  There's no limitation for number of objects, triangles in a mesh, etc.
Why there should be limitation in this kind of things?
Date: 3 Jun 1999 14:43:08
Message: <3756BE97.170380A@bahnhof.se>
Not true..
Try to use the sub (hmm, substring, can't remember it's function now) to
print the string. even if a concat loop works, the print doesn't..
#declare S = "."
#declare N = 100000;
#declare M = 0;
#while(M<N)
  #declare S = concat(S,".")
  #declare M = M +1;
#declare M = 0;
#while(M<N)
  #debug concat("\r",substr(S,0,M))
  #declare M = M +1;
this should show it....
//Spider
Date: 3 Jun 1999 16:28:56
Message: <3756d778.0@news.povray.org>
You are a very funny spider!!!
Good one....
Samuel.
Spider wrote in message <375### [at] bahnhofse>...
you
which
>Not true..
>#declare S = "."
>#declare M = 0;
>#while(M<N)
>  #declare M = M +1;
>#end
>#declare M = 0;
>#while(M<N)
>  #declare M = M +1;
>#end
>//Spider
Date: 3 Jun 1999 16:45:22
Message: <3756db52.0@news.povray.org>
My thoughts exactly,  I just hope I don't run into too many of them.
Samuel
Nieminen Mika wrote in message <37562bc8.0@news.povray.org>...
>  Why?
limitations
Date: 3 Jun 1999 17:15:09
Message: <3756E239.7A71B7@bahnhof.se>
> Good one....
> Samuel.
LMAO ....
Actually, there are several bugs in the concat() code.. parser not
caring for end ) in some cases, not error reporting and some other
stuff.
//Spider
Date: 3 Jun 1999 19:59:12
Message: <37570887.B1E1021C@t-online.de>
Nieminen Mika wrote:
>   Why?
Probably because nobody wanted to write such a function,
ANSI libc.a does not contain one, and POV was written in a
time before GNU hackers told that all limits are evil.
AFAIK glibc has an extension (getline) which does the job.
Ralf
Date: 3 Jun 1999 23:46:18
Message: <37573DE7.941E0077@geocities.com>
> > Good one....
> > Samuel.
> LMAO ....
> stuff.
> //Spider
so, should I go in and tweak all the string handling to deal in Unicode,
and also take out the limits while I'm in there?
Date: 4 Jun 1999 04:19:12
Message: <37577df0.0@news.povray.org>
Ralf Muschall <rmu### [at] t-onlinede> wrote:
: Probably because nobody wanted to write such a function,
: ANSI libc.a does not contain one, and POV was written in a
: time before GNU hackers told that all limits are evil.
: AFAIK glibc has an extension (getline) which does the job.
  filepos=ftell(InFile);
  for(i=StartingQuoteIndex+1; getc(InFile)!='"'; i++);
  fseek(filepos);
  char* String=malloc(i-StartingQuoteIndex-1);
  fgets(String, i-StartingQuoteIndex-1, InFile);
  What's so difficult here?
Date: 4 Jun 1999 08:04:21
Message: <3757B2A1.6409084E@bahnhof.se>
> > > Good one....
> > > Samuel.
> > LMAO ....
> > stuff.
> > //Spider
please do!
//Spider
