POV-Ray : Newsgroups : povray.bugreports : Help - is this a bug or op-err? Server Time
16 May 2026 21:11:58 EDT (-0400)
  Help - is this a bug or op-err? (Message 1 to 3 of 3)
Subject: Help - is this a bug or op-err?
Date: 13 May 1999 04:55:06
Message: <373a855a.0@news.povray.org>
I've placed a thin blue wall full of square holes in front of a white solid
wall, with a single light source to the left and above. The shadows I'm
getting don't make any sense at all.  Here's the code, plus a small .gif of
just the holes. With the light source as defined I'd expect the shadows to
be more or less uniform behind each hole.
This is just a test file - the original was more elaborate. That's where the
problem first cropped up. By the way, I'm using the Windows 3.1e version on
a Pentium 90, 64 meg/RAM.
Any help is appreciated.
Ken
camera
  location <0,0,-60>
  direction <0,0,2>
  up <0,1,0>
  right <4/3,0,0>
  look_at <0,0,1>
light_source {<-10000,10000,-45000> color White}
object
  box {<-20,-20,0>,<20,20,0.1>}
  pigment
    color White
  finish
    ambient 0.6
    reflection 0
object
  difference
    box {<-20,-20,-0.4>,<20,20,-0.41>}
    box {<-18,-1,-1>,<-16,1,1>}
    box {<-15,-1,-1>,<-13,1,1>}
    box {<-12,-1,-1>,<-10,1,1>}
    box {<-9,-1,-1>,<-7,1,1>}
    box {<-6,-1,-1>,<-4,1,1>}
    box {<-3,-1,-1>,<-1,1,1>}
    box {<0,-1,-1>,<2,1,1>}
    box {<3,-1,-1>,<5,1,1>}
    box {<6,-1,-1>,<8,1,1>}
    box {<9,-1,-1>,<11,1,1>}
    box {<12,-1,-1>,<14,1,1>}
    box {<15,-1,-1>,<17,1,1>}
  pigment
    color blue 0.4
  finish
    ambient 1
    reflection 0
Download 'shadtest.gif' (2 KB)
Preview of image 'shadtest.gif'
Subject: Re: Help - is this a bug or op-err?
Date: 13 May 1999 20:19:05
Message: <373B5DCF.6003874A@t-online.de>
The picture looks right (i.e. it looks how I'd expect it):
your lamp is almost infinitely away, causing the shadows to
be parallel images of the holes. OTOH, your camera is rather
close, thus the shadows (which are more far away from you than
the holes) seem smaller than the holes -- just as in the GIF.
If you want all shadows to look equal, put the lamp and the
camera into the same vertical plane parallel to the walls
(i.e. equal z for your orientation).
Ralf
Date: 14 May 1999 16:36:19
Message: <373c7b33.0@news.povray.org>
Ralf, thanks. You're right, that fixed it. It still seems counterintuitive.
In my example, the shadow behind the holes on the left look as expected, but
on the right it looks like the light source is to the right of the camera. I
suspect I need to visualize differently.
Ken
Ralf Muschall wrote in message <373B5DCF.6003874A@t-online.de>...
>Ralf
