POV-Ray : Newsgroups : povray.bugreports : Stack fault. Server Time
6 Feb 2026 03:10:33 EST (-0500)
  Stack fault. (Message 1 to 4 of 4)
Subject: Stack fault.
Date: 7 Apr 1999 14:15:24
Message: <370B91BE.FAB4477F@bahnhof.se>
Hello, I got a stack fault error while doing some macto coding.
I know it's not the depth of the loop(I loop the same way several times) but
when doing the final loop with a few #write() statements, it crashes.
Is there some kind of memory-leak in the #macro directive? I've come to belive
this after several crashes when using #macro and big #while loops.
(No, I had memory free)
povray 3.1e windows, watcom compile.
win 95 osr2.5.
povray as shell.
I can post the source for the crash, but it isn't predicatble to reproduce.(it's
a loong parse. 30-60 mins)
layout:
define a max
loop x->max
  loop y->max
    doo something
place in differennt macros.
I had a max of 250, and repeated around 15-20 times (random procedure)
Sorry that I can't help more.
all the loops were in #macro's
//Spider
                "Marian"
        By: "Sisters Of Mercy"
Subject: Re: Stack fault.
Date: 7 Apr 1999 15:52:30
Message: <370B9F3F.90D64196@bahnhof.se>
ok, got it again, same place..
I'm doing a debug render, let you know when I found out some more :-/
//Spider
                "Marian"
Subject: Re: Stack ---OVERFLOW---
Date: 7 Apr 1999 15:52:32
Message: <370BA74A.9D3904AA@bahnhof.se>
Sorry, read the wrong line in the last post..
I did a debug render on the Stack Overflow error, and found where it crashes.
Here is the code :
note: maxX = maxY = 200
Second test with maxX = maxY = 75 also crashes, at the number 42 this time.
a test with maxX = maxY = 50 worked...
Note : before this, 17 passes through the entire array was made, to calculate
the values.
/*useful for vector output */
#macro v2str(vVector)
  concat("<", str(vVector.x,-1,10), ",", str(vVector.y,-1,10), ",",
str(vVector.z,-1,10),">")
#macro WriteBoxes(sFilename)
  #fopen Out sFilename write
  #debug "\nCreating output file with union of boxes\n"
  #local s = 0.4999999;
  #write(Out, "union{\n")
    #local Y = maxY;
    #while (Y>0)
      #debug concat("\n: ",str(Y,0,0)," ")
      #local X = maxX;
      #while(X>0)
        #debug concat(str(X,0,0)," ")
        #write (Out, "box{",
v2str(<X-s,-0.001,Y-s>),",",v2str(<X+s,world[X][Y],Y+s> )
        #write (Out, " texture{") //Start texture
        #if(mod(X+Y,2))//The texture
          #write (Out, "tWhiteBox")
          #else
            #write (Out, "tBlackBox")
          #write (Out, "}}\n")//End texture and end box.
        #local X = X - 1;
      #local Y = Y - 1;
    #write (Out, "scale ", v2str(<1/maxX,1,1/maxX>), "\n" )
  #write (Out, "}\n")
  #fclose Out
And in the debug output, it goes from 200 : to 189 in Y, and when the 189 row is
finished, inside the 188'th, it crashes.
Is this something with a limited number of #write operations ???
If this isn't enough code, contact me and I can send the whole include file. (I
want to clean it a bit, and add comments before releasing it. as well as some
demos)
and here are the crash data.
PVENGINE.EXE caused fault #c00000fd in PVENGINE.EXE at address 0137:004a275e
To date, 15 fatal errors have been recorded in this program.  This particular
error was recorded 3 times.
Reported By:
CrashGuard v2.0.1
Report Date:
1999-04-07 18:38:27
WindowTitle:
POV-Ray - C:\graphic\POV-Ray for Windows v3.1\spider\Ground\Demo1.pov
Last Message:
MSG(00000000, 0000, 00000000, 00000000)
Program:
C:\GRAPHIC\POV-RAY FOR WINDOWS V3.1\BIN\PVENGINE.EXE
(03/19/99 23:21 - 1774592)
Registers:
EAX=00f92014 CS=0137
EIP=004a275e EFLGS=00010246
EBX=00000001 SS=013f
ESP=00f92000 EBP=00f92054
ECX=ffffff0c DS=013f
ESI=fffffffd FS=0fa7
EDX=00f92028 ES=013f
EDI=00f9205c GS=0000
Bytes at CS:EIP:
53 52 89 c6 29 d2 29 c9 29 ed 29 c0 8a 06 3c 00
Stack dump:
ffffff0c 00f9205c fffffffd 00f92054 00472226 00000031 00000000 00000000 00000000
00000000 00000000 00000000 00000000 00f92089 00000003 00000000
To date, 17 fatal errors have been recorded in this program.  This particular
error was recorded 5 times.
Reported By:
CrashGuard v2.0.1
Report Date:
1999-04-07 20:22:10
WindowTitle:
POV-Ray for Windows
Last Message:
Program:
Registers:
ESI=fffffffd FS=4b3f
Bytes at CS:EIP:
Stack dump:
//Spider
                "Marian"
Date: 8 Apr 1999 19:20:49
Message: <370D2A01.FD890800@bahnhof.se>
Tested in linux, parses with ease.
So the error is in the windows version(or in windows)
> win 95 osr2.5.
> povray as shell.
> layout:
> define a max
> loop x->max
>   loop y->max
>     doo something
> //Spider
>         [ spi### [at] bahnhofse ]-[ http://www.bahnhof.se/~spider/ ]
> What I can do and what I could do, I just don't know anymore
>                 "Marian"
//Spider
                "Marian"
