POV-Ray : Newsgroups : povray.bugreports : POVWin known bug #Win31-006 Server Time
28 May 2024 23:12:03 EDT (-0400)
  POVWin known bug #Win31-006 (Message 1 to 4 of 4)
Subject: POVWin known bug #Win31-006
Date: 10 Feb 1999 08:16:18
Message: <36C18693.6F69D494@compuserveNO-SPAM.com>
This known bug is currently being investigated.
> Subject: POV-Ray 3.1 property bug
> Date: Sun, 10 Jan 1999 03:46:44 -0500
> From: Shaun Mapel <Map### [at] aolcom>
> Newsgroups: povray.bugreports
Note from A.K. - This is one of at least three reports I've seen about this
alleged bug. I cannot, however, duplicate it on my system (Windows 95,
Pentium 200MMX, 64mb, POVWin v3.1a).
> Description: This happens with any scene I create or those shipped with
> POV-Ray. Have checked all files but can't seem to find this one.  Minor
> bug as I see it.  When using the editor in v3.1, right click on editor
> screen and choose Properties.  This brings up Windows properties that has
> 4 tabs to it.  When choosing Keyboard get a message: Access violation at
> address 0098858B in module 'CMAX101.DLL'. Read of address FFFFFFFF
> Trying any tab after this creates the following:
> PVENGINE caused an invalid page fault in
> module CMAX101.DLL at 014f:00987d68.
> Registers:
> EAX=00000000 CS=014f EIP=00987d68 EFLGS=00010202
> EBX=00000001 SS=0157 ESP=0077f18c EBP=0077f1b8
> ECX=00000010 DS=0157 ESI=00000bc4 FS=565f
> EDX=0077f5fc ES=0157 EDI=bff61681 GS=0000
> Bytes at CS:EIP:
> 8b 43 48 25 e0 03 00 00 f7 d8 1b c0 40 50 68 0f
> Stack dump:
> 0077f1a0 0000820e 0077f1b8 0077f1ea bff73663 00000bc4 00000110 00000000
> 005d3ee4 81e840cf 00000157 0077f1cc bff92894 48bf820e 000048bf 00000000
> Have tried this numerous times but get the same invalid page fault with
> the same registers.
> AMD K5 150 64MB
> W95b
> V3.1a.watcom.win32
Subject: Re: POVWin known bug #Win31-006
Date: 10 Feb 1999 09:07:54
Message: <36C1927C.7A47C49@pacbell.net>
In case this might help you as far as how many people are experiencing
similar problems let me add to the above.
  I too have had a several problems (minor as they are) with CMAX101.DLL
file errors. In all cases they are related to read of addresses ( which
I attribute to the fact I usualy have several files open in the editor at
once). There is nothing I can do to duplicate them and different things
happen at different times.
  Sometimes I lose all of my user settings at program start up, sometimes
I get a read error when trying to scroll up or down in the editor window.
Other times the program crashes or I get a program lock up and have to
use task manager to quit the program. On rare occassions I get a start up
CMAX101.DLL read of address error(s) warning and then Pov won't start at all.
Subsequent attempts at starting the program prove unsuccesful and the system
requires a full reboot to obtain functionality again.
  As I see it the CMAX101.DLL file is a little buggy but not crippled.
Windows 98, Pentium 200MMX, 128mb, POVWin v3.1a.
Ken Tyler
mailto://tylereng@pacbell.net
Date: 11 Feb 1999 01:46:06
Message: <36C27C89.761E37F4@aol.com>
Only 3 reports of this "keyboard tab" bug?
I thought it was rampant on most everyones P-R 3.1 and simply didn't see
fit to add my case in as well to what I thought were *all the others*.
So hey, add me in as number 4...
Win95 OSR2, IE4.01 SP1, 3.1.watcom.win32.r1, 233MMX Intel Pentium,
64Megs 66MHz SDRAM.
 Keyboard tab then Misc tab caused:
Access violation at address 00E9858B in module 'CMAX101.DLL'. Read of
address FFFFFFFF
module CMAX101.DLL at 0157:00e98ccd.
Registers:
EAX=00000000 CS=0157 EIP=00e98ccd EFLGS=00010202
EBX=bff61681 SS=015f ESP=0077f18c EBP=0077f1b8
ECX=00000010 DS=015f ESI=00000bc8 FS=47c7
EDX=0077f5fc ES=015f EDI=00000001 GS=0000
Bytes at CS:EIP:
8b 47 6c c1 f8 1e 50 68 04 04 00 00 56 ff d3 8b
Stack dump:
0077f1a0 0000820e 0077f1b8 0077f1ea bff735d9 00000bc8 00000110 00000000
005d5e2c 81e83e4f 0000015f 0077f1cc bff9222f 52f7820e 000052f7 00000000
Note that there is some deviation in addresses.
The same number shows up every time, I always see 0157: at the beginning
of the cmax101.dll error; and this other report shows this to be 014f:
> > Registers:
> > Bytes at CS:EIP:
> > Stack dump:
> > the same registers.
> > AMD K5 150 64MB
> > W95b
> > V3.1a.watcom.win32
 mailto:inv### [at] aolcom?PoV
Date: 11 Feb 1999 11:09:40
Message: <36C300AE.6A8A6118@compuserveNO-SPAM.com>
  That is the problem - some people can reproduce this bug but others cannot
repeat the trick at will. I can't make my system reproduce this bug at all
(and I suppose I should count my blessings).
  Please see also Barry Allyn's post in povray.windows. He is the CodeMax
author. Let's see if we can cooperate with Barry and get to the bottom of
this bug. Thanks, Ken.
- Alan
"Do you expect me to talk?" - James Bond
"No, Mr. Bond... I expect you to die!" - Auric Goldfinger
                                         "Goldfinger" (1964)
