POV-Ray : Newsgroups : povray.bugreports : Bug: divide by zero in scene file causes renderer to hang Server Time
16 May 2026 23:52:16 EDT (-0400)
  Bug: divide by zero in scene file causes renderer to hang (Message 1 to 3 of 3)
Subject: Bug: divide by zero in scene file causes renderer to hang
Date: 21 Oct 1998 22:40:02
Message: <362e8cf2.0@news.povray.org>
FYI,
I feel silly posting this, but I figured that you would want to know. The
code below will send the renderer into never never land.  .  The Stop button
will not work.  You can still use the editor and closing PovRay will halt
the renderer
     rotate <0,0,360/clock>
I am assuming it is caused by a divide by zero that is not handled
correctly.  I fixed my scene but it took a while to figure out.
Thanks
Tom
Subject: Re: divide by zero in scene file causes renderer to hang
Date: 28 Oct 1998 13:33:16
Message: <3637636c.0@news.povray.org>
Hi!
I found the same problem (or similar), but as it was generated
by a (faulty) while loop, it took some times for me to find it... I
think (but I did not test) that feeding a 'nan' or an 'inf' (as reported
by the #warning stream) to pov jams the parser in the auto-bounding
process. I believe it is the auto-bounding because (1) that is the status
displayed in the status bar when pov jams; (2) it did not happened
when the auto-bounding wasn't needed (number of objects under
the auto-bounding treshold).
I think the generation of such values should be trapped (weren't they in
earlier versions? I can't remenber...). Or they could be trapped when used
in an object (as degenarated shapes are).
Of course this isn't really a bug: we should try to avoid creating such
values. But it would be more confortable if pov handled them better.
Povingly,
Philippe
Date: 15 Nov 1998 13:18:30
Message: <jerry-1511981018300001@cx38767-a.dt1.sdca.home.com>
In article <3637636c.0@news.povray.org>, "Philippe Debar"
This is possibly related. I'd accidentally switched the numerator and
denominator in:
   #while (current_groove < groove_count)
      object { groove
         rotate <0,current_groove*360/groove_count,0>
      #declare current_groove = current_groove + 1;
so that it read
      object { groove
         rotate <0,groove_count*360/current_groove,0>
This was part of a difference; and current_groove starts from zero. There
was no error generated by the divide by zero; the difference object simply
didn't appear in the scene. It took me a bit to find the error because I
was looking for an error in size or translation rather than what I would
normally consider a fatal error in my code.
My fault, of course, but I would expect that divide by zero would generate
some sort of message.
Jerry
jer### [at] hoboescom
http://www.hoboes.com/jerry/                   e-mail hel### [at] hoboescom
What Your Children Are Doing: http://www.hoboes.com/html/NetLife/Children/
