POV-Ray : Newsgroups : povray.bugreports : Spotlight in media strange black circles Server Time
16 Dec 2025 14:50:44 EST (-0500)
  Spotlight in media strange black circles (Message 1 to 2 of 2)
Subject: Spotlight in media strange black circles
Date: 21 Dec 1998 05:15:46
Message: <01be2cca$768adae0$430a1f0a@pc0245>
When rendering the following scene, POV-Ray 3.1 shows some unrendered black
circles at the opposite direction of the spotlicht beams in the media.
Is this something known, and is there a workaround for this?
This scene is an altered version of the media2.pov example file:
// Persistence Of Vision raytracer version 3.1 sample file.
// Participating media with spotlights.
// The camera.
  location <0.5, 5, -10>
  right 4/3*x
  up y
  direction z
  angle 65
  look_at <0, 5, 0>
// Add media.
media {
  intervals 10
  scattering {1, rgb 0.02}
  samples 1, 10
  confidence 0.9999
  variance 1/1000
  ratio 0.9
// Spotlights pointing at shaft.
#declare Spot = light_source {
  <0, 0, 0> color rgb<1, 1, 1> * 3
  spotlight
  point_at <0, -1, 0>
  radius 2
  falloff 4
  media_attenuation on
#declare Spots = union {
  object { Spot }
  object { Spot rotate <0, 0, 10> rotate <0,   0, 0> }
//  object { Spot rotate <0, 0, 10> rotate <0,  30, 0> }
  object { Spot rotate <0, 0, 10> rotate <0,  60, 0> }
//  object { Spot rotate <0, 0, 10> rotate <0,  90, 0> }
  object { Spot rotate <0, 0, 10> rotate <0, 120, 0> }
//  object { Spot rotate <0, 0, 10> rotate <0, 150, 0> }
  object { Spot rotate <0, 0, 10> rotate <0, 180, 0> }
//  object { Spot rotate <0, 0, 10> rotate <0, 210, 0> }
  object { Spot rotate <0, 0, 10> rotate <0, 240, 0> }
//  object { Spot rotate <0, 0, 10> rotate <0, 270, 0> }
  object { Spot rotate <0, 0, 10> rotate <0, 300, 0> }
//  object { Spot rotate <0, 0, 10> rotate <0, 330, 0> }
object {
  Spots
  rotate <90, 0, 0>
  translate <0, 5, 0>
Subject: Re: Spotlight in media strange black circles
Date: 21 Dec 1998 10:07:52
Message: <367E63BD.8A153A53@zess.uni-siegen.de>
I could reproduce it. I have once had the same effect in a
scene of mine. Yet, I was able to get rid of it by playing
around with (read: cranking up) the antialias options inside
the media.
So I guess this is not a bug, but rather an alias problem.
Markus
> // The camera.
> camera {
>   right 4/3*x
>   up y
>   direction z
>   angle 65
>   look_at <0, 5, 0>
> // Add media.
> media {
>   intervals 10
>   samples 1, 10
>   confidence 0.9999
>   variance 1/1000
>   ratio 0.9
>   spotlight
>   point_at <0, -1, 0>
>   radius 2
>   falloff 4
>   object { Spot }
> object {
>   Spots
>   rotate <90, 0, 0>
>   translate <0, 5, 0>
Dipl.-Ing. Markus Becker
Siegen, Germany
