POV-Ray : Newsgroups : povray.binaries.utilities : export blender's smoke Server Time
1 Jun 2024 11:46:31 EDT (-0400)
  export blender's smoke (Message 1 to 10 of 12)
Subject: export blender's smoke
Date: 19 Mar 2018 10:00:00
Message: <web.5aafc23eb6e2f90f64bb7d620@news.povray.org>
I want to export smoke of blender. I wrote some code to read df3, and here
https://wiki.blender.org/index.php/Extensions:2.6/Py/Scripts/Render/POV-Ray
it says "A DF3 file (POV-Ray voxel format) is exported. I want to know where is
this file.
Subject: Re: export blender's smoke
Date: 19 Mar 2018 10:25:00
Message: <web.5aafc75717bef35764bb7d620@news.povray.org>
> this file.
I have tried render a scene from it.
Date: 19 Mar 2018 10:53:22
Message: <5aafcee2$1@news.povray.org>
>> this file.
I hope I can explain this.
In Blender with the render set to PovRay. Go to the scene properties
(camera icon). Open the "Output" property and you will see the o/p
directory. Mine reads /tmp/ Click the folder icon and Blender will show
you where the Pov file should be saved.
I've not tried using df3s myself. Although I found and reported a bug
using boids.
Keep us informed on how it goes.
Regards
Date: 19 Mar 2018 11:00:16
Message: <5aafd080$1@news.povray.org>
On 19/03/2018 14:53, Stephen wrote:
> Blender will show you where the Pov file should be saved.
One more thing
In Properties deselect "Delete files" and select POV Editor. That way
when you start to render PovRay will open and if the scene fails it will
be loaded into PovRay
Regards
Date: 19 Mar 2018 23:30:00
Message: <web.5ab07f5217bef35764bb7d620@news.povray.org>
> >> this file.
> using boids.
> Regards
>      Stephen
Hmm I tried change the output directory to D:\ but it doesn't save the files to
that. I found the .pov and output image on user\AppData\Local\Temp directory
where PovRay message shows. Opening the .pov I found the df3 path finally. It is
on
....user\AppData\Roaming\Blender Foundation\Blender\2.79\preview\smoke.df3"
Windows 7.
Thanks for the response.
Date: 20 Mar 2018 01:45:51
Message: <5ab0a00f$1@news.povray.org>
>>>> this file.
>> using boids.
>> Regards
>>       Stephen
> on
> Windows 7.
Sorry, I did some checking and that o/p location is for the render o/p.
My pov files are saved in the same location that the blend file is saved in.
I do have some files in %appdata%\Blender Foundation\Blender\2.79\preview
But they are associated with a file that had packed textures. I don't
know what happened there.
Regards
Date: 20 Mar 2018 02:35:00
Message: <web.5ab0ab1917bef35764bb7d620@news.povray.org>
I have another question: I found the df3 file of the blender exporter is just
one byte depth data, (I know povray df3 has one byte or two bytes variation), is
there an option to two bytes data? I wish my data is more accurate. Thank you.
Date: 20 Mar 2018 03:23:12
Message: <5ab0b6e0$1@news.povray.org>
I've not used Blender with df3s so I will leave Maurice to answer.
Regards
Date: 20 Mar 2018 18:00:49
Message: <5ab18491$1@news.povray.org>
hi,
you could use the 'df3util' program to convert from 8-bit to 16-bit (or
32), posted in p.b.u on 27th July last year.  hth.
regards, jr.
Date: 21 Mar 2018 06:02:04
Message: <5ab22d9c$1@news.povray.org>
>> this file.
Thanks for bringing up this topic. I had not tried Blender's smoke
before. It is very interesting playing with it.
The exported smoke texture I get is not the same in PovRay as rendered
in Blender.
Regards
