On 28/09/2025 06:53, yesbird wrote:
> Rook was uploaded and conversion also successful (attached), but you
> do not see it because pivot point is shifted and object is too far from
> origin. Just play with zoom/pan/rotation or fix it's position.
The same things with 'ghost' and 'hand' (attached).
I will think about automated objects positioning ...
YB
Download 'ghost.png' (130 KB)
Download 'hand.png' (153 KB)
Preview of image 'ghost.png'
Preview of image 'hand.png'
yesbird wrote:
> Bill, could you please look at the browser's console
> (usually F12) and send me content ?
Tried again just now - I see no grid or rotation, or controls for zooming or
panning.
When I was very new povver, I would draw arrows from the origin to objects or
light sources to help me find where things were when they were out of view.
You could also possibly have a labeled grid, and display the center of the
object in text. Maybe have a checkbox "Center at origin".
OK, maybe since a lot of objects are things that sit on a surface, have a second
checkbox that centers the object, and has its ymin set at 0.
- BW
Download 'meshconverter1.jpg' (353 KB)
Preview of image 'meshconverter1.jpg'
> panning.
> - BW
Bill, first of all please check if your browser supports WebGL:
https://webglreport.com/
Then select _console_ tab after pressing F12 and look for
errors there.
Axis will act as reference. I will think about centering after
collecting more information and samples.
Pan/Zoom/Scale can be controlled only by the mouse -
this is standard now and I don't want to implement complicated
environment.
Many thanks for testing, wishing well :).
YB
This is the point for discussion: should converter change
object's coordinates or just repack then into other format ?
I guess, this is the editor's function.
Maybe, it will be better just position the camera to look at object
and set acceptable zoom ?
In attachment: 'hand', loaded into C4D.
YB
Download 'hand_c4d.png' (404 KB)
Preview of image 'hand_c4d.png'
hi,
> this is standard now ...
great !!! that'll allow me to put the coffee cup and ashtray on the now unused
keyboard </grin>.
regards, jr.
> keyboard </grin>.
I mean lack of GUI.
YB
I have improved the default view on loading, now model sits at the
center and fits the screen perfectly.
YB
Brave supports WebGl1
Sometimes this is the result of older video drivers being rejected by the
browser. Try updating your video drivers if possible.
Also check out Get WebGL, or try installing the latest version of Chrome, or
Firefox.
> errors there.
three.module.js:29414 THREE.WebGLRenderer: A WebGL context could not be created.
Reason: Could not create a WebGL context, VENDOR = 0x8086, DEVICE = 0x0412,
GL_VENDOR = Google Inc. (Intel), GL_RENDERER = ANGLE (Intel, Intel(R) HD
Graphics 4600 Direct3D9Ex vs_3_0 ps_3_0, igdumdim64.dll -10.18.14.5180),
GL_VERSION = 10.18.14.5180, Sandboxed = yes, Optimus = no, AMD switchable = no,
Reset notification strategy = 0x8252, ErrorMessage = BindToCurrentSequence
failed: .
onContextCreationError @ three.module.js:29414
Reason: Failed to create a WebGL2 context.
failed: .
three.module.js:28990 THREE.WebGLRenderer: Error creating WebGL context.
WebGLRenderer @ three.module.js:28990
three.module.js:28980 Uncaught Error: Error creating WebGL context.
at new WebGLRenderer (three.module.js:28980:13)
at init (main.js:50:14)
at main.js:316:7
main.js:267 Uncaught TypeError: Cannot read properties of undefined (reading
'setSize')
at onWindowResize (main.js:267:12)
Many thanks for writing, and wishing you and everyone else the best in these
crazy times.
- BW
I would say it depends on what the user wants.
Blindly converting from one format to another, the computer doesn't "know".
I mean, that's fine for default behaviour, however I'd provide the option to
center in either of the two ways I suggested.
So here we have a "part" of what if likely a bigger object / assembly.
It would make sense that it is positioned in relation to the other parts, and so
changing that deletes that very carefully specified position.
Having a coffee mug 100 units in the air and WAY off center doesn't make a lot
of sense. We'd want to fix that obvious problem so that it doesn;t have to be
accounted for every time we instantiate the mesh, so it would get centered, with
y=0.
For other meshes, where having the center of the object at the origin would make
more sense from a rendering / modeling standpoint, then that would also be a
valid option.
But only the human user can look at that and know for sure.
- BW
> × This browser supports WebGL 2, but it is disabled or unavailable.
> Firefox.
Looks like WebGl1 is insufficient for Three.js and it wants WebGL2.
Did you tried it with Opera ?
"Don't give in without a fight" :).
YB
