POV-Ray : Newsgroups : povray.binaries.utilities : question? Server Time
22 Jul 2026 02:37:18 EDT (-0400)
  question? (Message 1 to 4 of 4)
Subject: question?
Date: 24 Oct 2001 06:55:56
Message: <3bd69e3c$1@news.povray.org>
If i want to print a poster of a povray image (or other).I need a 300 dpi
pictures to have a good print.
But screen only show 72/96 dpi, and i don't know how i could create a 300
dpi pictures.
Can someone give me advice about that?
Subject: Re: question?
Date: 24 Oct 2001 07:47:38
Message: <3BD6A9ED.6050603@videotron.ca>
> dpi pictures.
POV doesn't care about dpi (actually, it only does if you intend to
print your image using a printer that has a different horizontal and
vertical resolution).
If you want to print your image at 8"x10" with a 300 dpi resolution,
render it at 2400x3000 pixels.  If required, change the dpi info saved
in the file with an image editor.
Some people have recommended in the past rendering the image at half the
resolution of the printer - in this case 150 dpi - as most printers will
dither the image somewhat and you will not gain much in image crispness,
only image size, by going at full resolution.
You should also do a smaller test print beforehand as colors vary
greatly from your screen to a piece of paper.
/*   videotron.ca  */}camera{location<6,1.25,-6>look_at a orthographic}
Date: 25 Oct 2001 19:57:54
Message: <3bd8a702$1@news.povray.org>
200 dpi seems to be the current benchmark preferred by many industry people
I have spoken with. Beyond that you are probably wasting time and, I assume,
ink.
D.
"Francois Labreque" <fla### [at] videotronca> wrote in message
news:3BD### [at] videotronca...
dpi
300
> > dpi pictures.
> /*Francois Labreque*/#local a=x+y;#local b=x+a;#local c=a+b;#macro P(F//
> /*    flabreque    */L)polygon{5,F,F+z,L+z,L,F pigment{rgb 9}}#end union
> /*        @        */{P(0,a)P(a,b)P(b,c)P(2*a,2*b)P(2*b,b+c)P(b+c,<2,3>)
Date: 9 Nov 2001 17:25:07
Message: <3bec57c3$1@news.povray.org>
266dpi works better, and looks as good as 300dpi for most stuff...
-Ed
"Dennis Milller" <dhm### [at] mediaonenet> wrote in message
news:3bd8a702$1@news.povray.org...
people
assume,
> ink.
> D.
> dpi
> 300
> > > dpi pictures.
