POV-Ray : Newsgroups : povray.binaries.utilities : Poser Objects in POV Server Time
22 Jul 2026 12:57:15 EDT (-0400)
  Poser Objects in POV (Message 1 to 4 of 4)
Subject: Poser Objects in POV
Date: 11 Feb 1999 23:09:56
Message: <36C3A991.DD5C0028@warmann.com>
Hello,
I have written a small, merciless utility which will convert Poser 3.0
Objects into
POV-Ray mesh source.  So far, I have only tried it with the UV mapping
version of
POV-Ray and, offhand, don't think it works with standard POV.  I can
change that rather easily if anyone needs it.  The program is currently
less than what would be considered an alpha version (call it a
late-night hack), so consider yourself warned!  It'll be cleaned up
someday.  It's about 42K in size.
http://www.warmann.com/users/broken/utils/utils.html
Thanks,
Warren
Subject: Re: Poser Objects in POV
Date: 27 Feb 1999 10:31:19
Message: <36D81030.DC0C839D@inapg.inra.fr>
Hello
Thanks for sharing. I downloaded the utility and it works... but there is
one big problem (sorry if it's silly). How do I adapt the original Poser
maps to Nathan Kopp's uv mapping ??? I translated the original TIF files to
PNG, but the final mapping is all wrong. Any clue ?
Gilles Tran
Warren Mann wrote:
> Hello,
> Objects into
> version of
> Thanks,
> Warren
Date: 28 Feb 1999 02:32:44
Message: <36D8F19B.796893E2@ibm.net>
try to export as 3ds and use Win3DS2POV.
It is a full 3ds to pov convertor including uv mapping and image conversion.
You could find it at http://ourworld.compuserve.com/homepages/thbaier
-tb
Gilles Tran schrieb:
> Hello
> Gilles Tran
> Warren Mann wrote:
> > Hello,
> > Objects into
> > version of
> > Thanks,
> > Warren
Date: 1 Mar 1999 10:06:01
Message: <36DAAD3B.4D842486@inapg.inra.fr>
Sorry, it doesn't seem to recognise 3DS files from Poser. No error message, but
the inc file is empty (and no texture is generated)  :
 E:\temp\f1.3ds
 Generated by 3ds2pov by Thomas Baier (thb### [at] ibmnet)
#debug concat("Clock:",str(clock,5,2),"\n")
#debug "Parsing Inc started ...\n"
#debug "Parsing Inc finished\n"
That's all.
No explanation from the log :
Parsing E:\temp\f1.3ds ...
General animation settings:
  Length: 30
Missing scene camera
Adding Default Camera ...
Missing scene lights
Adding default lights
Parsing E:\temp\f1.3ds finished
There may be something in the way Poser creates 3DS files.
Looks like I'm doomed as far as Poser is concerned. I should be a POV snob and
write all them smooth_triangles by hand.
Gilles Tran
Thomas Baier wrote:
> Hi,
> -tb
