POV-Ray : Newsgroups : povray.binaries.utilities : Re: Q: Cylinder caculus? Server Time
5 Dec 2025 03:44:03 EST (-0500)
  Re: Q: Cylinder caculus? (Message 1 to 6 of 6)
Subject: Re: Q: Cylinder caculus?
Date: 8 Nov 1998 19:44:48
Message: <36463BBA.3216@aol.com>
I have a similar problem.
I want to have an object with its tail at <0,0,0> and its nose at a
given <x,y,z>.  I want to create it colinear with the X axis and simply
rotate it to be colinear with the <x,y,z> vector.
I've stumped myself on the math for this. How do I do this?
I tried with no success
rotate <0,atan2(z,x)/2/pi*360,atan2(y,x)/2/pi*360>
Thanks for any help.
Date: 9 Nov 1998 09:08:24
Message: <3646f758.0@news.povray.org>
Go to http://twysted.net/macroscope and look at John VanSickle's
Reorient macro.  It does exactly what you need.
Date: 9 Nov 1998 10:12:36
Message: <36471343.323C@aol.com>
Thanks.
I just moved and my hard disk is full to the brim. Wife says no new PC
until we finish unpacking, ie., 2001. Thus, I'm putting off going to POV
3.1 for a while.  I understand a bit of matrix algebra, but not the
following line from the recommended macro.  Is there a 3.02 way to do
this?
matrix < vX1.x, vY.x,vZ1.x, vX1.y,vY.y,vZ1.y, vX1.z,vY.z, vZ1.z, 0,0,0 >
matrix < vX2.x,vX2.y,vX2.z,  vY.x,vY.y, vY.z, vZ2.x,vZ2.y,vZ2.z, 0,0,0 >
Particularly, what does  vX1.x  mean?  The period confuses me.  I
understand the vcross and vnormalize functions.
Thanks again.
Date: 9 Nov 1998 10:34:34
Message: <36470b8a.0@news.povray.org>
On Mon, 09 Nov 1998 11:07:31 -0500, Greg M. Johnson <> wrote:
>Thanks.
>this?
>Thanks again.
It means "the x component of vX1".  Both of those lines should be legal
POV 3.02 syntax.  But you don't need a new PC, just a new hard drive. :)
Date: 9 Nov 1998 22:50:33
Message: <3647B959.5533@aol.com>
Thanks, but that web server for twyst's macro station now appears to be
down. Could you post that tiny little macro here?
Date: 10 Nov 1998 08:40:03
Message: <36484233.0@news.povray.org>
I can't get there either; Twyst has a broken CGI script.  Here's an
adaptation of the code, as seen in my rounded cylinder macro.  I've
changed all the 3.1-specific stuff to 3.02 stuff, so you can just
put this in an .inc file.  #declare Orientation to be your desired
vector, include this, then use transform{trans} where you'd usually
use rotate.  This assumes you used x as the original axis.
  #declare vX2=vnormalize(Orientation);
  #declare vY=vnormalize(vcross(x,vX2));
  #declare vZ1=vnormalize(vcross(x,vY));
  #declare vZ2=vnormalize(vcross(vX2,vY));
  #declare trans=transform {
    matrix < 1, vY.x,vZ1.x, 0,vY.y,vZ1.y, 0,vY.z, vZ1.z, 0,0,0 >
