POV-Ray : Newsgroups : povray.binaries.scene-files : for Sven Littkowski - Algorithmus Wanted Server Time
21 Jan 2026 00:42:32 EST (-0500)
  for Sven Littkowski - Algorithmus Wanted (Message 1 to 8 of 8)
Subject: for Sven Littkowski - Algorithmus Wanted
Date: 20 Feb 2018 15:10:00
Message: <web.5a8c80165f09b57ef6fe96310@news.povray.org>
Here is an example for getting equidistant objects via splines.
Original source (ABX) is included.
Norbert
Download 'equidistant spline_example.zip' (461 KB)
Subject: Re: for Sven Littkowski - Algorithmus Wanted
Date: 28 Feb 2018 09:40:00
Message: <web.5a96beb7fe98e6328f4894750@news.povray.org>
Here is a new version - using splines genereted with the help of vturbulence...
For rendering you have to get a hdr file from here:
https://www.openfootage.net/hdri-360-cres-croatia/
Norbert
Download 'wavy lines.pov.txt' (7 KB)
Date: 1 Mar 2018 03:15:15
Message: <5a97b693@news.povray.org>
> Norbert
Interesting.
Note: a lot of warnings generated in transforms.inc (line 39: scale by
0.0 in matrix column; and 187: normalizing zero-length vector) and
math.inc (lines243 and 275: normalizing zero-length vector). Some way to
avoid that? I do not see where those are generated.
Date: 1 Mar 2018 05:10:01
Message: <web.5a97d10ffe98e632d91233f30@news.povray.org>
> Interesting.
ABX used a variable called Accuracy in his Time_To_Lenght_Converter macro.
If you rise its value from 0.001 to 0.01 you get only one warning per spline and
not for every defined point.
I think this is because he used an arbitrarily defined step factor in this line:
#local Length = Length+vlength (Point-(Last*1.0003));
If you change 1.0003 to 1.00003, you avoid the matrix column warnings too.
But I really don't know why I get one zero length vector warning per spline.
My math skills...
Norbert
Date: 1 Mar 2018 05:25:00
Message: <web.5a97d4e8fe98e632d91233f30@news.povray.org>
Command back - ABX didn't introduce this factor. I used his code once many years
before and I forgot this little annoying thing.
In his original post he simply wrote: #local Length = Length+vlength
(Point-Last);
My fault.
Norbert
Date: 1 Mar 2018 07:09:53
Message: <5a97ed91$1@news.povray.org>
> (Point-Last);
> My fault.
> Norbert
Much better. Remains the zero-length vector... I shall ponder this a bit
more.
Date: 3 Mar 2018 15:43:19
Message: <5a9b08e7$1@news.povray.org>
>> vturbulence...
>> Norbert
> Interesting.
For the scale by zero, they come from constructs like scale Value*x.
When that appen, Value*x get promoted to <Value,0,0> generating two
warnings because scale 0 is not allowed.
You need to edit the file to replace all scale Value*x by
scale<Value,1,1>, all scale Value*y by scale <1,Value,1> and scale
Value*z by scale<1,1,Value>
For the problem with math.inc, make sure that you don't pass nor
generate any null vector.
A nul or zero-length vector don't have any direction and can't be
normalised to an unit length vector.
You may try adding this:
#if(vlength(Vector)=0) #declare vector=<1,0,0>; #end
Date: 23 Mar 2018 21:54:18
Message: <5ab5afca$1@news.povray.org>
Thanks everyone, seeing it just now, so belated.
http://www.avg.com
