POV-Ray : Newsgroups : povray.binaries.scene-files : decoy tc-rtc scene file Server Time
30 Apr 2024 23:20:47 EDT (-0400)
  decoy tc-rtc scene file (Message 1 to 4 of 4)
Subject: decoy tc-rtc scene file
Date: 31 Jul 2014 07:15:00
Message: <web.53da248f183fb6647dded57b0@news.povray.org>
This scene file contains WOW tripod, ant and lantern models the tripod is in an
include file the others are in the main scene file so not so easy to work with
as the code is very messy..
Feel free to use/change however you like.
Sean
Download 'decoy.zip' (31 KB)
Subject: Re: decoy tc-rtc scene file
Date: 1 Aug 2014 17:20:01
Message: <web.53dc04297d2e33a87a3e03fe0@news.povray.org>
> Sean
 instance of assumed_gamma ignored
File '/home/leonid/blender/files/blendScene.pov' line 412: Parse Warning: Black
 Hole repeat vector Y too small ; increased to 0.949
 Hole repeat vector Z too small ; increased to 0.4
File '/home/leonid/blender/files/blendScene.pov' line 413: Parse Warning: Black
 Hole repeat vector X too small ; increased to 0.65
 Hole repeat vector Y too small ; increased to 1.199
 Hole repeat vector Z too small ; increased to 0.5
Parsing 67K tokens
File '/home/leonid/blender/files/blendScene.pov' line 2118: Parse Error:
 Expected '( or [', ) found instead
Fatal error in parser: Cannot parse input.
Render failed
Date: 2 Aug 2014 18:05:03
Message: <web.53dd5f9b7d2e33a87dded57b0@news.povray.org>
> Parsing 67K tokens
> Render failed
> Parsing 67K tokens
> Render failed
What version of POV are you using? I have re-downloaded the source attached to
this thread, set useHDR value to zero near the top of the file (or change the
HDR settings to a valid .hdr file if you want) and it renders OK. I do get the
black hole warnings but these do not affect the render.
I do not get the final error/fatal error you are getting so wonder if it is a
POV version issue or are you trying this with your Blender plugin (as you have
called it blendScene.pov ;-).
If I get a chance I will download blender and your plugin/extension to take a
look.
Sean
Date: 2 Aug 2014 18:59:21
Message: <53dd6d49$1@news.povray.org>
>> Parsing 67K tokens
>> Render failed
I have also try to render the scene and I have got some errors but the
main is the lack of the HDR image. Maybe try to modifiy the code and
replace the missing file by another - it is what I have made and all works.
Lionel.
Do not judge my words, judge my actions.
http://www.avast.com
