"Samuel Benge" <stb### [at] hotmail com> wrote:
> Hi,
> This is a utility for creating geodesic spheres and domes. It aims to be both
> easy to use, and extensible: the end-user designs their own triangle object.
> It also includes a special gradient function that makes certain operations
> easier.
> Happy Raytracing!
> Sam
Could I ask for a macro that creats position points on sphere in an array? Or it
has existed?
I would like to make a light dome and light bulbs which have raytrace picture
elegant like some other people do in this newsgroup.
thanks.
Excellent, Sam! Thank you indeed.
> has existed?
> thanks.
Somebody might have already posted some code for that. If not, ask your question
in the general section :)
No Problem, Thomas. It was on my to-do list anyway; I just finally got around to
doing it :)
> has existed?
Try
http://news.povray.org/povray.binaries.images/thread/%3C461ba1e1%40news.povray.org%3E/?mtop=241021
and
http://news.povray.org/povray.binaries.scene-files/thread/%3C461efe8a%241%40news.povray.org%3E/
These are from 2007 so the code probably needs to be adapted for 3.7.
To clarify, the links are not about evenly spaced points
on a sphere, but about creating points for a light dome.
Christian Froeschlin <chr### [at] chrfr de> wrote:
> > has existed?
> Try
> and
It seems useful and have many information.
Previously, I found that Samuel Benge's macro seems easy to use, so I asked for
this directly.
Thank you.
I haven't checked out those links, but I've got a good way to produce an
arbitrary number of evenly-spaced points on a sphere. It's based on the Fermat
Spiral, but adapted to work on a sphere (can't remember where I found it):
union{
#local NPoints = 256;
#local Radius = 1;
#local Inc = pi * (3 - sqrt(5));
#local Off = 2 / NPoints;
#for(K, 0, NPoints-1)
#local Y = K * Off - 1 + (Off / 2);
#local R = sqrt(1 - Y*Y);
#local Phi = K * Inc;
#local ThisPoint = <cos(Phi)*R, Y, sin(Phi)*R>*Radius;
sphere{ThisPoint, .1}
pigment{rgb 1}
> this directly.
> Thank you.
My geodesic sphere code is not the best choice, as it produces duplicate points,
and you can't just /choose/ any number of points you want (when dealing with a
light dome made up of numerous light_sources, you would probably want an easy
way to fine-tune quality over speed). The above code should work fairly well for
producing an array of lights for a light dome.
Maybe somebody who has experience working with light domes can put it to use.
Sam
>>> has existed?
>> Try
>> and
> this directly.
> Thank you.
Both of those used an now obsolete version of megapov. Megapov is a test
bed branch of POV-Ray.
You can now use high dynamic range images directly when using the
version 3.7. It also provide illumination when combined with radiosity.
You can also do a search for "light dome". It's a way to generate lights
according to a high dynamic range image. The lights placement and
density generated is not uniform as it depends on the bright parts of
the source image.
> union{
> #local Radius = 1;
> #end
> pigment{rgb 1}
> Sam
Oh, you are kind. Thanks.
Although I have no experience with light dome, I intend to make one.
I will try it.
I'm unfamiliar with megapov except for viewing its mechanical simulation several
years ago, I know that pov-ray 3.7 can use hdr image directly. However those
links contain the theme you just mentioned such as lights placement depends on
the brightness of the point.
It is a bit hard to me, and with my poor english it is harder when I read them.
