POV-Ray : Newsgroups : povray.binaries.scene-files : Geodesic.inc Server Time
16 Mar 2026 19:14:40 EDT (-0400)
  Geodesic.inc (Message 4 to 13 of 13)
<<< Previous 3 Messages Goto Initial 10 Messages
Subject: Re: Geodesic.inc
Date: 30 Oct 2013 20:30:01
Message: <web.5271a3e7c0b30abfd7d2abf60@news.povray.org>
"Samuel Benge" <stb### [at] hotmailcom> wrote:
> Hi,
> This is a utility for creating geodesic spheres and domes. It aims to be both
> easy to use, and extensible: the end-user designs their own triangle object.
> It also includes a special gradient function that makes certain operations
> easier.
> Happy Raytracing!
> Sam
Could I ask for a macro that creats position points on sphere in an array? Or it
has existed?
I would like to make a light dome and light bulbs which have raytrace picture
elegant like some other people do in this newsgroup.
thanks.
Date: 31 Oct 2013 03:53:55
Message: <52720c93$1@news.povray.org>
Excellent, Sam! Thank you indeed.
Date: 31 Oct 2013 15:45:01
Message: <web.5272b213c0b30abf1353ccf10@news.povray.org>
> has existed?
> thanks.
Somebody might have already posted some code for that. If not, ask your question
in the general section :)
Message: <web.5272b25cc0b30abf1353ccf10@news.povray.org>
No Problem, Thomas. It was on my to-do list anyway; I just finally got around to
doing it :)
Date: 1 Nov 2013 13:47:12
Message: <5273e920@news.povray.org>
> has existed?
Try
http://news.povray.org/povray.binaries.images/thread/%3C461ba1e1%40news.povray.org%3E/?mtop=241021
and
http://news.povray.org/povray.binaries.scene-files/thread/%3C461efe8a%241%40news.povray.org%3E/
These are from 2007 so the code probably needs to be adapted for 3.7.
Date: 1 Nov 2013 13:49:06
Message: <5273e992@news.povray.org>
To clarify, the links are not about evenly spaced points
on a sphere, but about creating points for a light dome.
Date: 2 Nov 2013 10:20:00
Message: <web.527509b2c0b30abfdccc31210@news.povray.org>
> > has existed?
> Try
> and
It seems useful and have many information.
Previously, I found that Samuel Benge's macro seems easy to use, so I asked for
this directly.
Thank you.
Date: 2 Nov 2013 14:00:01
Message: <web.52753d54c0b30abf6949fcad0@news.povray.org>
I haven't checked out those links, but I've got a good way to produce an
arbitrary number of evenly-spaced points on a sphere. It's based on the Fermat
Spiral, but adapted to work on a sphere (can't remember where I found it):
union{
 #local NPoints = 256;
 #local Radius  = 1;
 #local Inc = pi * (3 - sqrt(5));
 #local Off = 2 / NPoints;
 #for(K, 0, NPoints-1)
  #local Y = K * Off - 1 + (Off / 2);
  #local R = sqrt(1 - Y*Y);
  #local Phi = K * Inc;
  #local ThisPoint = <cos(Phi)*R, Y, sin(Phi)*R>*Radius;
  sphere{ThisPoint, .1}
 pigment{rgb 1}
> this directly.
> Thank you.
My geodesic sphere code is not the best choice, as it produces duplicate points,
and you can't just /choose/ any number of points you want (when dealing with a
light dome made up of numerous light_sources, you would probably want an easy
way to fine-tune quality over speed). The above code should work fairly well for
producing an array of lights for a light dome.
Maybe somebody who has experience working with light domes can put it to use.
Sam
Date: 2 Nov 2013 23:27:48
Message: <5275c2b4$1@news.povray.org>
> Christian Froeschlin <chr### [at] chrfrde> wrote:
>>> has existed?
>> Try
>> and
> this directly.
> Thank you.
Both of those used an now obsolete version of megapov. Megapov is a test
bed branch of POV-Ray.
You can now use high dynamic range images directly when using the
version 3.7. It also provide illumination when combined with radiosity.
You can also do a search for "light dome". It's a way to generate lights
according to a high dynamic range image. The lights placement and
density generated is not uniform as it depends on the bright parts of
the source image.
Date: 4 Nov 2013 03:45:00
Message: <web.52775dd5c0b30abfdccc31210@news.povray.org>
> union{
>  #local Radius  = 1;
>  #end
>  pigment{rgb 1}
> Sam
Oh, you are kind. Thanks.
Although I have no experience with light dome, I intend to make one.
I will try it.
I'm unfamiliar with megapov except for viewing its mechanical simulation several
years ago, I know that pov-ray 3.7 can use hdr image directly. However those
links contain the theme you just mentioned such as lights placement depends on
the brightness of the point.
It is a bit hard to me, and with my poor english it is harder when I read them.
