POV-Ray : Newsgroups : povray.binaries.scene-files : Geodesic.inc Server Time
26 Mar 2026 12:29:12 EDT (-0400)
  Geodesic.inc (Message 11 to 13 of 13)
Subject: Re: Geodesic.inc
Date: 2 Nov 2013 14:00:01
Message: <web.52753d54c0b30abf6949fcad0@news.povray.org>
> To clarify, the links are not about evenly spaced points
> on a sphere, but about creating points for a light dome.
I haven't checked out those links, but I've got a good way to produce an
arbitrary number of evenly-spaced points on a sphere. It's based on the Fermat
Spiral, but adapted to work on a sphere (can't remember where I found it):
union{
 #local NPoints = 256;
 #local Radius  = 1;
 #local Inc = pi * (3 - sqrt(5));
 #local Off = 2 / NPoints;
 #for(K, 0, NPoints-1)
  #local Y = K * Off - 1 + (Off / 2);
  #local R = sqrt(1 - Y*Y);
  #local Phi = K * Inc;
  #local ThisPoint = <cos(Phi)*R, Y, sin(Phi)*R>*Radius;
  sphere{ThisPoint, .1}
 pigment{rgb 1}
"And" <49341109@ntnu.edu.tw> wrote:
> It seems useful and have many information.
> Previously, I found that Samuel Benge's macro seems easy to use, so I asked for
> this directly.
> Thank you.
My geodesic sphere code is not the best choice, as it produces duplicate points,
and you can't just /choose/ any number of points you want (when dealing with a
light dome made up of numerous light_sources, you would probably want an easy
way to fine-tune quality over speed). The above code should work fairly well for
producing an array of lights for a light dome.
Maybe somebody who has experience working with light domes can put it to use.
Sam
Date: 2 Nov 2013 23:27:48
Message: <5275c2b4$1@news.povray.org>
> Christian Froeschlin <chr### [at] chrfrde> wrote:
>> And wrote:
>>> Could I ask for a macro that creats position points on sphere in an array? Or it
>>> has existed?
>> Try
http://news.povray.org/povray.binaries.images/thread/%3C461ba1e1%40news.povray.org%3E/?mtop=241021
>> and
http://news.povray.org/povray.binaries.scene-files/thread/%3C461efe8a%241%40news.povray.org%3E/
>> These are from 2007 so the code probably needs to be adapted for 3.7.
> this directly.
> Thank you.
Both of those used an now obsolete version of megapov. Megapov is a test
bed branch of POV-Ray.
You can now use high dynamic range images directly when using the
version 3.7. It also provide illumination when combined with radiosity.
You can also do a search for "light dome". It's a way to generate lights
according to a high dynamic range image. The lights placement and
density generated is not uniform as it depends on the bright parts of
the source image.
Date: 4 Nov 2013 03:45:00
Message: <web.52775dd5c0b30abfdccc31210@news.povray.org>
> union{
>  #local Radius  = 1;
>  #end
>  pigment{rgb 1}
> Sam
Oh, you are kind. Thanks.
Although I have no experience with light dome, I intend to make one.
I will try it.
I'm unfamiliar with megapov except for viewing its mechanical simulation several
years ago, I know that pov-ray 3.7 can use hdr image directly. However those
links contain the theme you just mentioned such as lights placement depends on
the brightness of the point.
It is a bit hard to me, and with my poor english it is harder when I read them.
