POV-Ray : Newsgroups : povray.binaries.scene-files : eval_pigment() and trace() HowTo Server Time
24 Jun 2026 01:51:58 EDT (-0400)
  eval_pigment() and trace() HowTo (Message 6 to 15 of 15)
<<< Previous 5 Messages Goto Initial 10 Messages
Subject: Re: eval_pigment() and trace() HowTo
Date: 9 Jul 2016 02:52:42
Message: <57809f3a@news.povray.org>
On 7-7-2016 16:02, Bald Eagle wrote:
> I see:
> #declare WriteStrands = off; //set to 'on' for the first pass.
> Isn't there a way to just check if the file exists, and if not, create it?
> I looked - but it's not clear that this is possible.
> Seemed like a useful and desirable feature to be added, if that's the case.
In fact, there is a simple reason why I did not use the file_exists(S)
function, now that I think about it. It is that you may want to test
different settings before choosing the final ones (at least that is how
I work) and so - except for the very first time - there is always a file
present.
Date: 9 Jul 2016 06:38:34
Message: <5780d42a@news.povray.org>
Am 09.07.2016 um 08:52 schrieb Thomas de Groot:
>> I see:
>> it?
>> case.
> present.
You could use something like:
    #declare WriteStrands = off; // set to 'on' to force re-writing
    #if (!file_exists(...)) #declare WriteStrands = on; #end
Date: 9 Jul 2016 07:17:16
Message: <5780dd3c$1@news.povray.org>
>>> I see:
>>> it?
>>> case.
>> present.
But, that would always set it to on, even when you want it to be off, or
do I misunderstand this?
Date: 9 Jul 2016 07:42:44
Message: <5780e334@news.povray.org>
Am 09.07.2016 um 13:17 schrieb Thomas de Groot:
>>>> I see:
>>>> it?
>>>> case.
>>> present.
It would always set it to on _if_ the file does not already exist, so
you don't need to manually set it to on for the first run.
Of course if there are any use cases where you might want to have _no_
file at all, then this is of no use.
Date: 10 Jul 2016 03:00:47
Message: <5781f29f$1@news.povray.org>
>>>>> I see:
>>>>> it?
>>>>> case.
>>>> present.
I think you misunderstand my use of the on/off switch. The writing away
of data is only meant as time saving later on when reading the data
(always faster than having to do the complete calculations for each
run). So, the switching off of the writing section (once you are
satisfied with the written data) is essential. A file_exist switch can
only make sense to check the existence of a file in the "Read" section
of the macro.
Date: 10 Jul 2016 09:29:00
Message: <57824d9c$1@news.povray.org>
Am 10.07.2016 um 09:00 schrieb Thomas de Groot:
>>>>>> I see:
>>>>>> create
>>>>>> it?
>>>>>> case.
>>>>> how
>>>>> file
>>>>> present.
Not at all. But you apparently misunderstand my use of `file_exists()` ;)
> The writing away
> of the macro.
No, the `file_exists()` test makes perfect sense before the file
generation. It's pretty simple:
- You use `#declare WriteStrands = on;` while experimenting, forcing a
(re-)write on every run.
- You use `#declare WriteStrands = off;` once you're ok, suppressing a
re-write.
- In case the file does not yet exist, the `#if (!file_exists(...))
#declare WriteStrands = on; #end` overrides your choice and forces a
write, thus making sure that the finished scene can be rendered as-is,
with no tampering necessary even if the data file happens to be missing
for some reason.
Date: 11 Jul 2016 02:40:23
Message: <57833f57@news.povray.org>
>>>>>>> I see:
>>>>>>> create
>>>>>>> it?
>>>>>>> case.
>>>>>> how
>>>>>> file
>>>>>> present.
That was a hypothesis I had not considered of course. ;-)
>> The writing away
>> of the macro.
> re-write.
> for some reason.
I see. Not sure if I want to do it that way though. I keep this in mind
for when I 'really' need it :-)
Date: 12 Jul 2016 01:25:00
Message: <web.57847dd1734cd25733c457550@news.povray.org>
> For general information purposes,
> eval_pigment is a macro that is defined in functions.inc as shown below.
> #macro eval_pigment(pigm, vec)
>     #local fn = function { pigment { pigm } }
>     #local result = (fn(vec.x, vec.y, vec.z));
>     result
> #end
It's always been interesting to me that the macro was designed to work only with
the r-g-b color components, and not with the f and t components as well. I
assume there's a reason for that (a technical one?); but evaluating a color like
rgb <.3,.5,.7,.4,.2> will return just the 'opague' colors, not the "colors +
f-and-t mix."
Or maybe my own logic about 'color mixing' is in error, when it comes to
*translucent* color shades (?). I admit that the effects of f and t on a color
are not the same as, say, adding *white* to get a pastel tint. But eval_pigment,
as-is, gives a kind of false result when working with translucency-- or so it
seems.
Date: 12 Jul 2016 02:00:27
Message: <5784877b$1@news.povray.org>
Am 12.07.2016 um 07:20 schrieb Kenneth:
>>     result
>> #end
> f-and-t mix."
And what exactly would make you think so?
If you try it out, you'll find that eval_pigment() works perfectly fine
with full-fledged rgbft colours.
Maybe you somehow got the impression that the `.x`, `.y` and `.z`
referred to the pigment colour's components? They don't. They instead
refer to the input point, passing the individual coordinates as separate
parameters to the pigment function.
Date: 12 Jul 2016 03:06:01
Message: <578496d9$1@news.povray.org>
That is interesting! I did not know that but it makes sense indeed. Good
to know.
