POV-Ray : Newsgroups : povray.binaries.scene-files : Sky simulation Server Time
24 Jun 2026 03:43:36 EDT (-0400)
  Sky simulation (Message 1 to 10 of 38)
Subject: Sky simulation
Date: 7 Jun 2013 07:51:18
Message: <51b1c936@news.povray.org>
See example images posted in p.b.i
SkySim.inc is the macro, SkySimTestGround.pov is a simple example of a
scene using the macro.
Download 'windows-1252' (7 KB) Download 'windows-1252' (3 KB)
Subject: Re: Sky simulation
Date: 7 Jun 2013 10:54:55
Message: <51b1f43f$1@news.povray.org>
Very good. Thanks very much indeed. Much better of course than the
simple example I gave :-)
Date: 30 Jun 2013 08:00:01
Message: <web.51d01cc859bb6361916440570@news.povray.org>
Hello, I try your macro but I've got an error on line:
#local xyYtoR = function (x,y,Y){ (x/y* 3.2406  -1.5372 + (1-x-y)/y *
-0.4986)*Y/SkyMaxLuminance }
where Y seems undefined.
I am wrong?
Date: 30 Jun 2013 13:13:32
Message: <51d0673c@news.povray.org>
> I am wrong?
Try calling the function this way:
xyYtoR(x,y,1)
This is a reason to NOT use "X", "Y" or "Z" as user variable names. It
can lead to some confusion.
Date: 1 Jul 2013 03:31:45
Message: <51d13061@news.povray.org>
> I am wrong?
Y is one of the parameters for the function, so it becomes defined when
the function is called. What version of POV are you using? I've tried it
on 3.6 and 3.7 with no issues.
 > It can lead to some confusion.
I wouldn't normally do such a thing, but the colour space used by the
algorithm is Yxy. My POV version didn't complain or get confused about
using Y and y, so this makes the equations easier to read. I suppose I
could have used _Y or something.
Date: 1 Jul 2013 06:40:00
Message: <web.51d15b7b59bb6361916440570@news.povray.org>
> > I am wrong?
It works (not fine but with no errors) when I change Y by z:
#local xyYtoR = function (x,y,z){ (x/y* 3.2406  -1.5372 + (1-x-y)/y *
I know this is not the good value but I try to see what happens.
I use v3.6 and v3.7 with the same result.
Date: 1 Jul 2013 07:54:13
Message: <51d16de5$1@news.povray.org>
If you change the Y to z in the parameter list then just change the Y to
z in the equation too:
-0.4986)*z/SkyMaxLuminance }
That should then work the same as the original version.
Date: 1 Jul 2013 08:25:01
Message: <web.51d174e159bb6361916440570@news.povray.org>
Thanks, I go to try this when my render in works will stop.
Date: 1 Jul 2013 08:54:56
Message: <51d17c20$1@news.povray.org>
OK but I still find it odd you get an error when using Y as a parameter.
What is the exact error you get, can you copy and paste it here for us
to see?
If you copy the below code into an empty POV document (so just 1 line) -
does it work?
#local xyYtoR = function (x,y,Y){ x+y+Y }
Date: 1 Jul 2013 09:10:01
Message: <web.51d17e3959bb6361916440570@news.povray.org>
> to see?
> does it work?
It work with a simple scene, I can't understand what's happens!!! With
sky_sim.inc ...
OOOPS!!! I've find, I have a variable declared Y... Excuse me...
