![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Subject: Simulated urbanism macro scene: version 2013.04.08
Date: 8 Apr 2013 04:00:40
Message: <51627928@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I made a number of code improvements to the macros, following
Christian's advice.
In the Orientation() macro I also changed the #while() loop into a
#for() loop.
I have a major question though.
If, in the Urbanism() macro, I change the #while() into a #for() loop, I
get a different end result! IMO this should not be the case as no
changes whatsoever are made to any random parameter. You can test this
yourself by:
1) change the line:
#while (Counter < Numbers)
into:
#for (Counter, 1, Numbers)
and 2) comment out the line: #local Counter = Counter + 1;
A second question follows from the docs about the #for() loop (my italics):
[quote]
A new #for loop construct is now available for simple loops incrementing
Identifier from Start to End /(inclusive)/ with the given Step size. The
default Step size is +1.0.
[/quote]
However, in the code and setting Verbose=on, #for() goes till End-1.
Probably my skull thickness but any idea?
Download 'windows-1252' (16 KB)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> Christian's advice.
> #for() loop.
> yourself by:
> 1) change the line:
> into:
> [quote]
> [/quote]
> Thomas
IMHO the #for loop goes to the end value if reaches it e.g.:
#for (I, 1, 10)
#warning Str(I)
will show all the numbers from 1 up to 10, but :
#for (I, 1, 10, 2)
#warning Str(I)
will only show 1, 3, 5, 7, 9 because the 11 that follows is greater than 10.
On the other hand a #while (I<10) statement will only show the numbers up to 9
because the symbol "<" means *strictly* smaller than. If you want 10 to show up
you should use #while (I<=10).
regards,
Marc
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Subject: Re: Simulated urbanism macro scene: version 2013.04.08
Date: 8 Apr 2013 10:17:36
Message: <5162d180$1@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> #for (I, 1, 10)
> #warning Str(I)
> #end
> #for (I, 1, 10, 2)
> #warning Str(I)
> #end
Yes. However, in my code #for (Counter, 1, 10) with default step=1, the
Counter only shows the numbers 1 to 9...
I am sure I am missing something obvious here :-(
Of course, but there lies not my problem.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 8 Apr 2013 10:40:14
Message: <5162d6ce@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
More bizarre than that: #for(Counter, 1, Numbers) where Numbers=50 the
last number shown is 49, but for all other values (as far as I have
tested now) the result is correct. Have I met a freakish behaviour just
by chance? Something to do with rounding effect?
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> Thomas
What messages do you get when you do the following:
#for (I, 1, 10)
#warning Str(I)
Or does the Counter gets modified during the loop?
Marc
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 8 Apr 2013 17:57:18
Message: <51633d3e@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Am 08.04.2013 16:40, schrieb Thomas de Groot:
Can't confirm that one. Are you computing Numbers somehow? Maybe due to
rounding effects you end up with Numbers = 49.9999 or some such.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 9 Apr 2013 03:19:11
Message: <5163c0ef$1@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
To nimda and Clipka:
I got it! :-)
The #for() loop definitely does *not* work correctly for my particular
case, while the #while() loop does. The reason is that Counter should
only be incremented *if* the #inside() test is passed as negative (not
inside object). With the #for() loop, Counter is *always* incremented
whatever the result of the #inside() test.
Conclusion: I should use the #while() loop in this case as easiest
coding procedure.
My first question about the different results in placing houses is now
also answered. It derives from the above of course.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 9 Apr 2013 04:04:41
Message: <5163cb99@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Am 09.04.2013 09:19, schrieb Thomas de Groot:
> I got it! :-)
Yeah, that /could/ make a difference ;-)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
