POV-Ray : Newsgroups : povray.binaries.scene-files : A poly 16 file for Le_Forgeron Server Time
17 Apr 2026 16:52:52 EDT (-0400)
  A poly 16 file for Le_Forgeron (Message 1 to 10 of 18)
Subject: A poly 16 file for Le_Forgeron
Date: 15 Dec 2010 20:14:43
Message: <4d096803@news.povray.org>
I've ask in the Povray Bug Tracking System to raise the maxpower of the poly
object with one power to 16.
Le_Forgeron asked me for a genuine poly 16 file to test the system. It's
attached to this post.
If someone else is interested, there is a working poly 8 file too, so you
can play with a high power object.
Both files produces spirals that are build from a mathematical described
distorted Oval Torus (poly 8 and poly 16), followed by chopping up the
distorted torus in peaces that builds a spiral. No mesh or Isosurface is
used.
Jaap Frank
Download 'us-ascii' (3 KB) Download 'spiral_poly8.png' (135 KB) Download 'us-ascii' (11 KB) Download 'us-ascii' (36 KB) Download 'us-ascii' (17 KB)
Preview of image 'spiral_poly8.png'
Subject: Re: A poly 16 file for Le_Forgeron
Date: 16 Dec 2010 13:51:14
Message: <4d0a5fa2@news.povray.org>
Le 16/12/2010 02:14, Jaap Frank nous fit lire :
> poly object with one power to 16.
There is a syntax error on line 318. Can you fix it (just post the
corrected line) ?
/*  x^6.y^2.z^4	  */   ,
-12*T6*P4*R4-48*T4*P2*R2*(5*R2+A2)-40*T2*(R2-A2)*R2+3*A2)
Notice the closing parenthesis with no opening.
So far I just tried to raise the limit (easily)... but it render only a
yellow stone and black sky.
I might take more time than expected if I have to found an actual
surface. (oh, well, I might provide a new syntax as well... it's too
late for 3.7 anyway). At least your demo scene confirmed me that a lot
of values are 0.
You are right about the code of binomial(): it is dead. (the array is
used all the time, due to the parser limiting the order)
In fact it is silly computing the binomial coefficient by the absolute
formula b(k,r) = k!/((k-r)! * r!), using optimisation of factoring the
numbers in stacks and removing common parts, to avoid big numbers.
It is also silly, because it try to factor for all odd numbers instead
of just primes. What a waste of modulo computation.
It is far simpler to know that it's the pascal's triangle, with
b(k,r)=b(k-1,r-1)+b(k-1,r) when r>0 and r<k;
b(k,0)=1 as well as b(k,k)=1.
Must have been some "smart" coding of that old time.
32 bits unsigned int can store down to depth 35.
64 bits go down to depth 69.
> you can play with a high power object.
> used.
> Jaap Frank
Date: 16 Dec 2010 16:52:02
Message: <4d0a8a02$1@news.povray.org>
>"Le_Forgeron"  schreef in bericht news:4d0a5fa2@news.povray.org...
>corrected line) ?
>/*  x^6.y^2.z^4   */   ,
-12*T6*P4*R4-48*T4*P2*R2*(5*R2+A2)-40*T2*(R2-A2)*(R2+3*A2)
The opening parenthesis is just before the last R2 > > > >  ^
In case I forgot an other one, all the factors look alike and have a
R2 and an A2 between the parenthesis and no other variables.
A few times there is a (R4 -A4).
Did you take a look at the poly8 file? It should give the same result.
I can't guarantee that the poly 16 formula is correct, but the result
looks oke.
>of values are 0.
When I searched my old stuf I found a manual for POV 0.5 beta,
together with one for POV-Ray 1.0gw (27 april 1992). There were
no poly objects in those times. I think they were introduced in version 2
or maybe stil later in version 3. That would make the code at least
15 years old.
But you are right, the Triangle of Pascal is far more simpler. I always
used the triangle to show the beauty of mathematics to students who
found mathematics dull and to difficult. They were always amazed
they could write out (a+b)^7 in a few moments and sometimes began
to like mathematics a bit because of that.
I would say, keep the hard code until pow 16 and use your way to
expand it if necessary.
Is it possible that high powers gives problems with the minimum (or
maximum) values that can be used. Values of 0.001 for x,y or z are
quit normal, but raised to power 16 you already get 1E-48. It may be
the reason for limiting to maxpower 15 in the past.
If that's a problem, stick to maxpower 16 then.
Thanks for reacting to my request.
Jaap Frank
Date: 16 Dec 2010 17:01:37
Message: <4d0a8c41@news.povray.org>
>"Jaap Frank"  schreef in bericht news:4d096803@news.povray.org...
>poly
>used.
>Jaap Frank
In the poly 16 file there was one parenthesis avaporated in line 318.
In this file it is corrected, so overwrite it with this one. Le_Forgeron
is changing the allowed maxpower, so I hope we can use the file
in the future.
Jaap Frank
Date: 18 Dec 2010 13:52:44
Message: <4d0d02fc@news.povray.org>
Le 16/12/2010 23:01, Jaap Frank nous fit lire :
> in the future.
> Jaap Frank
I rendered the poly 16... part of it are noisy. I need to probably to
adjust some settings in the solver & poly code (if it can fix something
at all)
To ease the input, I'm adding a new syntax (no more ordering, you can
omit the coefficient at 0, it save a bit !)
#declare Spiral_Shape = object { polynom { 8
/*  x^8         */   xyz(8,0,0):  1
/*  x^6.y^2     */   xyz(6,2,0):  2*T2
/*  x^6.z^2     */   xyz(6,0,2):  4
/*  x^6         */   xyz(6,0,0):  -2*((1-P2*T2)*R2+A2)
/*  x^5.y       */   xyz(5,1,0):  -8*R2*Slope*T2
/*  x^4.y^4     */   xyz(4,4,0):  T2*T2
/*  x^4.y^2.z^2 */   xyz(4,2,2):  6*T2
/*  x^4.y^2     */   xyz(4,2,0):  2*T2*((1-P2*T2)*R2-A2)
/*  x^4.z^4     */   xyz(4,0,4):  6
/*  x^4.z^2     */   xyz(4,0,2):  -2*((3-2*P2*T2)*R2+3*A2)
/*  x^2.y^2.z^4 */   xyz(2,2,4):  6*T2
/*  x^2.y^2.z^2 */   xyz(2,2,2):  2*T2*((2-P2*T2)*R2-2*A2)
/*  x^2.z^6     */   xyz(2,0,6):  4
/*  x^2.z^4     */   xyz(2,0,4):  -2*((3-P2*T2)*R2+3*A2)
/*  x^2.z^2     */   xyz(2,0,2):  2*(R2-A2)*((1+P2*T2)*R2-A2)
/*  x.y.z^4     */   xyz(1,1,4): -8*R2*Slope*T2
/*  y^4.z^4     */   xyz(0,4,4):  T2*T2
/*  y^2.z^6     */   xyz(0,2,6):  2*T2
/*  y^2.z^4     */   xyz(0,2,4):  2*T2*(R2-A2)
/*  z^8         */   xyz(0,0,8):  1
/*  z^6         */   xyz(0,0,6):  -2*(R2+A2)
/*  z^4         */   xyz(0,0,4):  (R2-A2)*(R2-A2)
/*  C           */   xyz(0,0,0):  0.000000001      sturm    }
// end poly
} // end object
Download 'neo8.pov.txt' (8 KB)
Date: 18 Dec 2010 19:45:00
Message: <4d0d558c@news.povray.org>
>"Le_Forgeron"  schreef in bericht news:4d0d02fc@news.povray.org...
>> In the poly 16 file there was one parenthesis evaporated in line 318.
>> in the future.
>> Jaap Frank
>at all)
I'm curious, is the central line along the y-axis disappeared?
If it is still there, then the fact that C = 0 may be the answer to that.
Maybe it is not possible to solve very high powers with the poly solver
correctly and you get a bit fuzzy answers.
I've find an other derivation leaving to poly 12, but the result
was not what I wanted, but it rendered well. Interested?
>// end poly
>} // end object
Splendid, that's far more easier! It makes the file better to read.
Do you start with all zero's and put the given factors in
their correct position? I expect something like that will
be the way to do that.
Date: 19 Dec 2010 03:40:45
Message: <4d0dc50d$1@news.povray.org>
Le 19/12/2010 01:45, Jaap Frank nous fit lire :
> Do you start with all zero's and put the given factors in their correct
Yes. (I didn't want to change the internal, only the interface to input
the coefficients)
Date: 19 Dec 2010 07:05:01
Message: <web.4d0df3ea43e11b0ec734aecd0@news.povray.org>
http://www.merriam-webster.com/dictionary/polynom
Tor Olav
http://subcube.com
Date: 19 Dec 2010 12:55:26
Message: <4d0e470e$1@news.povray.org>
Le 19/12/2010 13:00, Tor Olav Kristensen nous fit lire :
Your suggestion is welcome...
Date: 19 Dec 2010 13:25:00
Message: <web.4d0e4bd543e11b0ec734aecd0@news.povray.org>
How about polynomial ?
Tor Olav
http://subcube.com
