POV-Ray : Newsgroups : povray.binaries.scene-files : Colefax lens flare macro and output gamma Server Time
17 Apr 2026 18:10:40 EDT (-0400)
  Colefax lens flare macro and output gamma (Message 1 to 9 of 9)
Subject: Colefax lens flare macro and output gamma
Date: 13 Aug 2010 01:26:11
Message: <4c64d773@news.povray.org>
Chris Colefax's lens flare macro seems to be broken when used with
assumed_gamma. I've tried adjusting the colors using a macro I created,
but the effects are still too intense. Does assumed_gamma affect things
like filter and transmit as well as color values? What other
modifications do I need to make to the script (see attached example)?
http://isometricland.com
Download 'lnsefcts_mod.zip' (9 KB)
Subject: Re: Colefax lens flare macro and output gamma
Date: 13 Aug 2010 05:43:21
Message: <4c6513b9$1@news.povray.org>
Am 13.08.2010 07:26, schrieb SharkD:
Strictly speaking, assumed_gamma affects none of these. The only effect
it has is on the output image (which is why the approach is inadequate,
and assumed_gamma is deprecated again as of version 3.7).
In this sense, it does indeed affect any and all effects, including
those generated with filter and/or transmit.
Date: 14 Aug 2010 00:38:02
Message: <4c661daa$1@news.povray.org>
Any way to fix the scene? I get the same broken results in 3.7 as I do
in 3.6.2 with assumed_gamma set to 1.
Date: 14 Aug 2010 05:14:35
Message: <4c665e7b$1@news.povray.org>
IIRC ... using radiosity was the culprit. Could be thinking of something
else, but I suppose turning off rad (if you're using it) is worth a shot.
Date: 15 Aug 2010 11:05:51
Message: <4c68024f$1@news.povray.org>
Sheesh ... the more I thought about this, the more it just sounded plain
stupid ... or maybe "Dazed and Confused" (digs out Led Zeppelin CD to
clears out the cobwebs) ... after looking through some old crib notes
seems like I was thinking of "NKFlare" and media :-!
Date: 15 Aug 2010 23:33:20
Message: <4c68b180@news.povray.org>
I attached the problem files. Rad is off.
Date: 17 Aug 2010 19:24:07
Message: <4c6b1a17@news.povray.org>
On a hunch I tried changing the transmit using the following macro, but
the results weren't correct.
#macro gamma_transmit_adjust(in_transmit)
   #local out_gamma = 1/2.2;
   pow(in_transmit, out_gamma)
Date: 20 Aug 2010 18:23:53
Message: <4c6f0079@news.povray.org>
Am 18.08.2010 01:24, schrieb SharkD:
Do you indeed mean "not correct", or rather "not as expected"?
Maybe the lens flare macro wasn't designed to be physically correct, but
just to "look good" (in POV-Ray 3.6 without "assumed_gamma", i.e. in a
physically /incorrect/ renderer); in that case fixing the lens flare
macro might be non-trivial.
Date: 20 Aug 2010 18:45:46
Message: <4c6f059a$1@news.povray.org>
Yeah, that's kind of the point of this thread. ;)
