![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Version 7 is out! See my post in p.b.images for details.
Sam
Download 'lb7.zip' (21 KB)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I'm getting an "invalid or corrupted" error message...
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Where are you getting this message? It sounds like the zip file is
corrupted, but I checked it with both Filzip and 7-Zip, and everything
seems fine.
Have you tried downloading it again?
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> seems fine.
It seems to be a problem with Windows XP. Windows gives the same error message
for the hf_tools zip file. I'll give 7-zip a try. Thanks again!
Dave Blandston
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
7-zip opened the file. My guess is there's some proprietary formatting involved.
I'm excited to try out your code now.
Dave Blandston
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> Regards,
> Dave Blandston
Apparently a 7-ZIPped ZIP,the archive should be extracted with 7-ZIP(7Z.EXE e
LB7.ZIP),& the result unzipped as usual. This applies also to Sam's
HF_TOOLS.ZIP.
Don't know why,but 7-ZIP's output(in both cases) is '[Content]',which I renamed
TMP.ZIP before using the excellent util ENZIP.
Tony Mayne
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>> Regards,
>> Dave Blandston
> HF_TOOLS.ZIP.
> Tony Mayne
As you are using 7zip, make sure that you actualy output a ZIP file and
not a .7Z file.
I use IZArc, and it will correctly uncompress a valid archive even if it
don't have the right extention. It's quite possible that other utilities
may not be able to cope with a *.7Z file ranamed as *.ZIP. I think of
winzip, PKZip and the integrated windows zip support.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
