POV-Ray : Newsgroups : povray.binaries.scene-files : f_mandelbulb.010.zip Server Time
16 May 2026 12:26:53 EDT (-0400)
  f_mandelbulb.010.zip (Message 11 to 20 of 20)
Subject: Re: Happy 2,0,1,0 Quaternion-power 'Bulb!
Date: 20 Jan 2010 11:00:00
Message: <web.4b572776b2edd653be2080550@news.povray.org>
"makc" <mak### [at] gmailspamcom> wrote:
> "Tor Olav Kristensen" <tor### [at] TOBEREMOVEDgmailcom> wrote:
> > [SNIP]
> > // It can be used like this:
> > #declare MandelBulbFn = MandelBulbFunction(8, 3, 8, pi/2, 8, 5)
> could you please make a pov file with that for all the newbies to learn from?
Ok. See the attached pov-file.
But it may not be the easiest example for new users to learn from.
Note that if one want to see more details at higher powers,
then this smoothing expression should probably be changed:
  1/(I - ln(ln(_r)/ln_R_BO)/ln_R_Pwr)
Tor Olav
http://subcube.com
Download 'mandelbulb.pov.txt' (3 KB)
Date: 20 Jan 2010 15:56:53
Message: <4b576e15@news.povray.org>
That is very nice, indeed, and far easier to read than my formulation.
It probably renders faster than my recursive SDL hack, too.
A few quick renders seems to indicate your formula may match one of the
bizarre "negative power" variations related to the tricorn fractal
rather than one of the standard mandelbulb functions.  (You should still
be able to get the "classic" mandelbulbs by messing with the phase and
the signs of the powers.)  I don't have time right now to examine it in
detail, but I would take a look at the use of the built-in f_ph() and
f_th() functions; they don't correspond directly to published mandelbulb
functions[1], nor to the conventional spherical coordinate system[2].
Plain old isosurfaces are tough for new users to tackle at all, and more
power to those that do!
Can you explain what you mean here, or post an example?
The smoothing function should not smooth the surface itself, it should
just decrease the actual max_gradient of the function and make it easier
for the root solver to find the surface.  To get to higher iteration
surfaces, lower the isosurface threshold to a value closer to zero (from
1/2 as it is now to 1/3, 1/4, and so on to get more and more fractal
detail.)
~David
[1]
http://www.skytopia.com/project/fractal/2mandelbulb.html#formula
[2]
http://en.wikipedia.org/wiki/Spherical_coordinate_system#Coordinate_system_conversions
Subject: Re: f_mandelbulb.020.zip
Date: 6 Feb 2010 01:45:01
Message: <web.4b6d0ecb2676bfb8f99d05c80@news.povray.org>
I messed with the f_mandelbulb internal function, squeezed about 10-15% better
performance out of it, and posted what I have so far below.  (Note the handy
sincos() function in the standard library saving a couple of trig calls.)
Interestingly, I also found an additional 10-15% improvement in render time by
seriously overloading the processors with one to two hundred POV-Ray worker
threads on eight cores and using smaller render block size (16 for 640*360
images).  I'm guessing the extra switching cost is more than offset by keeping
the floating-point pipelines full.
~David Wagner
DBL f_mandelbulb(FPUContext *ctx, DBL *ptr, unsigned int) // 79
{  // Coded by David Wagner, and based on
   // Daniel White's original squaring formula,
   // Paul Nylander's generalization and phi phase shift formulation,
   // the Normalized Iteration Count Algorithm,
   // and Abram Hindle's POV-Ray internal function patch.
   DBL cx=PARAM_X, cy=PARAM_Y, cz=PARAM_Z;
   DBL halfp_r   = PARAM(0);// Radial power exponent.
   DBL p_theta   = PARAM(1);// Power of elevation theta.
   DBL p_phi     = PARAM(2);// Power of azimuth phi.
   DBL phase     = PARAM(3);// Phase shift of phi.
   int i_bailout = PARAM(4);// Maximum number of iterations.
   DBL r2_bailout = pow(PARAM(5),2);// Assumed divergence radius.
   DBL x = cx, y = cy, z = cz;
   DBL r2 = x*x + y*y + z*z;
   DBL rp, sinpphi, cospphi, sinptheta, cosptheta;
   int i=1;
   halfp_r*=0.5;
   while(i < i_bailout && r2 < r2_bailout) {
       ++i;
       rp = pow(r2,halfp_r);
       sincos(p_phi * atan2(z,sqrt(x*x + y*y)) + phase, &sinpphi, &cospphi);
       sincos(p_theta * atan2(y,x), &sinptheta, &cosptheta);
       z = cz + rp * sinpphi;
       x = cx + cosptheta * rp*cospphi;
       y = cy + sinptheta * rp*cospphi;
   if (i < i_bailout) {
       return 1/( i + log(log(r2_bailout) / log(  r2))
          / (log(halfp_r)+0.693147180559945) );
   }//          ==log(2*halfp_r)
   return 1/( i + log(log(r2_bailout) / log(1+r2))
Date: 6 Feb 2010 04:28:54
Message: <4b6d3656$1@news.povray.org>
Except that it is non-standard...
	Thorsten
Date: 6 Feb 2010 04:35:24
Message: <4b6d37dc$1@news.povray.org>
Your guess is wrong as long as you counted "cores" as the logical number of
cores seen by the operating system - including simultaneous multi-threading
capabilities your processor may have.
What you are most likely seeing is that your OS gives your application
slightly higher priority as a whole if it is running more threads, either
because it is designed to detect compute-heavy applications or because its
internal scheduling is on a thread rather than process basis.
	Thorsten
Date: 6 Feb 2010 10:23:00
Message: <4b6d8954$1@news.povray.org>
>     Thorsten
Ah, thanks.  It's a GNU C extension.  I'll make a note to guard its use
with a macro, and use an alternative with other compilers.
Google does not make it easy to find anything about sincos() since it
returns results for sin_cos (where _ is any or no character).
~David
Date: 6 Feb 2010 10:49:06
Message: <4b6d8f72$1@news.povray.org>
>> 10-15% better
>> handy
  AFAIK it's part of the C99 standard.
Date: 6 Feb 2010 10:50:56
Message: <4b6d8fe0$1@news.povray.org>
> of cores seen by the operating system - including simultaneous
> multi-threading capabilities your processor may have.
I'm counting the eight physical cores in the two quad-core AMD 2344 HE
sockets F on the motherboard.
> either because it is designed to detect compute-heavy applications or
> because its internal scheduling is on a thread rather than process basis.
Interesting.  This is a on recent install of Ubuntu 9.10 Server Edition
with their "server" kernel.  I'll do some better timing tests after I
set up another one of these boards headless.
~David
Date: 6 Feb 2010 14:05:00
Message: <web.4b6dbd462676bfb8f99d05c80@news.povray.org>
> >> 10-15% better
> >> handy
So far as I can find, Gnu[1], Intel, HP[2], and Sun[3] include sincos() in libm
for C99.  It may take a bit more digging to sort out what compiler flags (if
any) are needed to use it with each of these.  I haven't found an answer for
Apple.
~David
[1] http://linux.die.net/man/3/sincos
[2] http://docs.hp.com/en/5992-2854/ch09s12.html
[3] http://docs.sun.com/app/docs/doc/816-5172/sincos-3m?a=view
Date: 7 Feb 2010 15:14:01
Message: <4b6f1f09$1@news.povray.org>
> Apple.
  Well, at least with gcc if your program is C, then the compiler option
would be "-std=c99" (I really can't understand why that's not the
default). With C++ you could try "-std=c++0x".
